11-27-2011, 02:23 PM | #1 |
Overdrive from an AA truck hi-lo box
Thought someone on this forum mentioned a conversion made from a truck high/low box for use as an overdrive. Could that be posted? Send me a PM with the contact info. for the guy who makes them up. Thanks, Bob.
11-27-2011, 06:17 PM | #2 |
Re: Overdrive from an AA truck hi-lo box
An article in the N-D'11 Restorer, page 24 & following describes a car with one of these installed. The article says that it was modified by John Laaker, but not much more than that.
11-27-2011, 07:18 PM | #3 |
I saw that too and it piqued my interest! Looks like it would be a fun, period appearing way to have an overdrive in an AA.
11-27-2011, 08:40 PM | #4 |
anybody know John Laaker. I will check the mafca roster. thought i saw this on fordbarn. senior moment again. bob
11-27-2011, 09:11 PM | #5 |
John Laaker is a good friend of mine-known him for 30 years. He lives in Longmont,CO. He is a 30+ year Mafca member, and has built several of those overdrives including the one in that car (in the latest Restorer). These underdrives turned into overdrives work pretty well, but a bit noisy, as they are a planetery gear transmission, turned backwards. They are a good low cost overdrive alternative. I have driven them, but never owned one.
Steve Becker Bert's Model A Center |
11-28-2011, 03:25 PM | #6 |
11-29-2011, 01:33 AM | #7 |
They are not High Low. They are direct drive and underdrive. I would think a Mitchell Gear Splitter would be a much better idea.
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? |
11-29-2011, 11:55 AM | #8 |
03-12-2012, 05:04 PM | #9 |
can anyone post more info on running a AA underdrive, run reversed to make it an overdrive?
03-12-2012, 05:21 PM | #10 |
03-12-2012, 08:19 PM | #11 |
For an AA it may be practical to turn the Dual-High trans around & have an overdrive as they are so slow,even with the so called high-speed gears.But for an A,I dont think its very practical as they are a heavy unit & would be noisy in OD. OMO.
03-13-2012, 05:24 PM | #12 |
im not to worried about the noise, has anyone got any first hand info on the conversion?
03-13-2012, 05:57 PM | #13 |
The original post read;
"Thought someone on this forum mentioned a conversion made from a truck high/low box for use as an overdrive." I simply stated "They are not High Low. They are direct drive and underdrive." Is that not correct?
03-13-2012, 09:39 PM | #14 |
They are turned around backwards to become an overdrive, although Ford installed them as an underdrive in the 1928-1929 AA trucks. They do work , they are a bit noisy, but given the choice, I would have a Mitchell. Those that buy them form John Laaker, generally buy them simply because they cost much less then the Mitchell. I have driven several Model A's with them installed, and , if it were my car, i would save my $$ and buy a Mitchell.
03-13-2012, 10:39 PM | #15 |
I cant see that you could turn a high-low unit around backwards in a 29 AA where you could really use one,as the brake cross shaft passes over the skinny end of the casing, am I missing something?
03-13-2012, 11:05 PM | #16 |
I have been thinking about this conversion for a long time. I would be interested in trying one.
IF IT CAN NOT BE FIXED WITH BLASTING WIRE, JB WELD OR DUCT TAPE ---IT CAN NOT BE FIXED Do not get me started on the stupidity of ethanol. I think one of the monitors is from Iowa and he will delete the thread. |
08-22-2018, 12:24 PM | #17 |
I have one of the boxes if you wanted to try converting it yourself. I want $435 for it.
Looking for original 1932 3-window coupe parts to complete my project. Also looking for 1936 ford roadster body /parts. Lots of 1941 Mercury convertible parts for sale. |
08-22-2018, 01:18 PM | #18 |
08-22-2018, 01:56 PM | #19 | |
I have heard they can be used as an overdrive but yes are noisy and run hot after awhile as previously mentioned are planetary gears being run backwards. FYI the planetary gears have no bearings - just an oil bath and an oil hole so you can see how they would heat up over time if driven backwards.
1929 Model AA - Need long splash aprons! |
