Old 04-03-2021, 09:11 PM   #1
RalphG
RalphG's Avatar
Default The Mercury Yesterday
Nice spring weather here and the yard has dried up enough that I could get out with the Merc for some driving yesterday. Worked great. Got some photos and video. The drone went a little out of control on auto pilot and hit the back window of the Merc but luckily no damage to either.
https://youtu.be/FtM11z1qmHo
RalphG is offline   Reply With Quote
Old 04-03-2021, 09:38 PM   #2
mercman from oz
mercman from oz's Avatar
Default Re: The Mercury Yesterday
Good to see that you can get the old Mercury out for a drive again. Take care and keep safe.
Old 04-04-2021, 03:20 AM   #3
51 MERC-CT
51 MERC-CT's Avatar
As usual an interesting video.
Regarding oil on the floor, it's most likely a faulty seal between the torque converter and transmission that allows the oil to drain back into the transmission, causing an over full condition
Then the oil will drip out of the shift lever shaft (which probably has a poor seal)
To verify this, when it has not been run for a period of time and before starting, check the oil level. It will most likely show way over full.
Kinda looks like your reading shows below low to me.
Old 04-04-2021, 05:38 AM   #4
HDowse
HDowse's Avatar
Hi Ralph, nice video and glad you’re running the old Merc on a beautiful day. I spied the rear window of an earlier Ford car in your garage. What do you have hiding over there? Hunt
HDowse is online now   Reply With Quote
Old 04-04-2021, 09:31 AM   #5
RalphG
RalphG's Avatar
You noticed the 39 Deluxe that has been here even longer than I have. (My parent's wedding car) Here is a photo from back when it was still driving. I still need to order one of Skip's rebuilt coils for it.
Old 04-04-2021, 09:35 AM   #6
RalphG
RalphG's Avatar
Then the oil will drip out of the shift lever shaft (which probably has a poor seal)[/IMG]
I was really hoping it was just a pan gasket causing the leak. I'll do the level check as you suggested. It looked in the safe range on the dipstick to me. What amazes me is how clean this oil stays. I've never changed oil and I don't know if my dad ever did.
Old 04-04-2021, 11:12 AM   #7
T Scott
I would change the oil. When oil sits for a long time the sediment sinks to the bottom and it looks clean when you check it. Also the Ph changes when burned sulfur compounds contaminate the oil and it becomes more acidic and corrosive. Not good.
T Scott is offline   Reply With Quote
Old 04-04-2021, 11:25 AM   #8
34PKUP
34PKUP's Avatar
Really? in an automatic transmission?
34PKUP is offline   Reply With Quote
Old 04-04-2021, 12:07 PM   #9
HDowse
HDowse's Avatar
That’s a nice ‘39 Fordor, Ralph. I hope you are able to get it going sometime soon.
Old 04-04-2021, 04:10 PM   #10
flatford8
flatford8's Avatar
Great video Ralph!!....always a pleasure to take a ride in your Merc with you!!..Thanks,Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver
Old 04-04-2021, 05:27 PM   #11
petehoovie
petehoovie's Avatar
The only thing nice about being imperfect is the joy it brings to others....
"Silver rings, your butt! Them's washers!"
"We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969
https://www.youtube.com/watch?v=7NReUd2_0u0
