Old 06-02-2018, 12:41 PM   #1
MGG
MGG's Avatar
Default 8BA Thermostat Housings
On my 8BA, the two thermostat housing castings on the top front of each head have a 1-1/4 inch OD hose connection point. The radiator hoses are 1-3/4 inch ID. Is there a good leak-proof method of attaching the radiator hoses there?
MGG is offline   Reply With Quote
Old 06-02-2018, 12:51 PM   #2
42merc
42merc's Avatar
Default Re: 8BA Thermostat Housings
Go to the parts store-buy a 3" long piece of 1-1/4" hose. Take the hose home & cut in 2 equal pieces- then install the piece on to the t- stat housing- then install the 1-3/4" hose over the "adapters".
Works good, no leaks, lasts long time.
Drake & others sell a S/S housing with 1-3/4" outlets at about $40.00 a pair.
42merc is offline   Reply With Quote
Old 06-02-2018, 01:09 PM   #3
MGG
MGG's Avatar
Thanks - Any idea why ford did not just build the housings with 1-3/4 inch outlets to begin with?
Old 06-02-2018, 01:15 PM   #4
42merc
42merc's Avatar
Design change in '48 with the trucks & carried over to all '49-'53 Fords & Mercs.
Why--? Henry 2, after the war hired a group of GM engineers, different thinking.
