06-12-2018, 01:18 PM | #21 |
Re: Do I need a new worm in the steering box?
I have changed several 2 tooth worms over the years without using a press (which I dont have) . I put the shaft in a good heavy vice and wrap a piece of light cardboard around it so the shaft is not marked .(I suppose it doesnt really matter if it is) I heat the worm with the handheld propane torch,it does not need to be smokin hot . I use a brass drift and the worm will punch off . Rotate the drift to avoid bending the shaft although I doubt you could bend it with a drift . At first it is reluctant to move but once the worm is on the move it will come off,you might have to reheat . To install the worm it will go on easier than taking off . I do heat the worm a bit . Be sure to put the worm on the right way round or it will not go fully home . There is a relief bored in one end that is the end that goes on first . I use a fairly hefty brass or copper headed hammer ( called the "copper bopper" ! ) Hit it squarely so not to damage the end race .Use eye protection
John in cool summer evening Suffolk County England .. |
06-13-2018, 12:37 PM | #22 | |
Here is my thinking on this, The adjustments on the steering box are to adjust for changes (wear). With that said, my view is that the steering sector replacement on my car, by observation, is the problem. All the slop in steering, seems to be in the sector bearing allowing it to kind of move around a bit. I will replace the sector and sector bearing plate with a new bearing and two tooth sector, slap it all back together and adjust it per the method that can be found on the web for my Gemmer box. If that works, I am all done, if not, well then I will spend the bucks to do the worm too! |
06-13-2018, 07:11 PM | #23 |
I am really happy to hear that the "aluminum plate on the floor" method worked for someone else. I about lost it when the guy started pounding on that thing, but it worked! Glad it worked for someone else....
06-14-2018, 09:02 AM | #24 |
Hi Alaska Mike, it was your posting back in February that prompted me to try that method, very simple and works slick. I did coat the shaft and the worm w/oil before the installation.
06-14-2018, 11:03 PM | #25 |
It is much easier to heat the worm on a stove, and freeze the shaft. Install quick. I have done hundreds of them
06-15-2018, 01:07 AM | #26 |
Didn’t you need to replace the worm in the bottom of your tequila bottle once? |
06-15-2018, 03:26 PM | #27 | |
My thoughts exactly !!! I replace them both . I don't risk bending the shaft . I order the shaft with the worm gear in place . It costs more but it is so much easier and turns out so much better . |
Thread Tools | |
Display Modes | |
