Old 02-28-2016, 11:37 PM   #1
katy
katy's Avatar
Default Transmission shift lever, bottom end, should it be straight?
Should this part of the shaft be straight? I suspect it should be, but don’t know. A couple of books I have don’t mention it one way or the other. It doesn’t show up too well in the picture but it’s got a fair bend in it. I can straighten it after I rebuild the ball, if need be.
I understand that the ball should be round but on page 115 of Jim Schild’s book “Restorer’s Model a Shop Manual” it says that the ball should be built up on the front and rear, but do not build up the sides.
What’s the consensus on this?
Tnx, Ken
Old 02-28-2016, 11:52 PM   #2
jw hash
jw hash's Avatar
Default Re: Transmission shift lever, bottom end, should it be straight?
yes it should straight. and the ball need built up to 1/2" ..
jw hash is offline   Reply With Quote
Old 02-29-2016, 12:10 AM   #3
Drive Shaft Dave
When I rebuilt my shifter I built up the sides. Had no problem.
Drive Shaft Dave is offline   Reply With Quote
Old 02-29-2016, 12:46 AM   #4
Mike V. Florida
Mike V. Florida's Avatar
Originally Posted by katy View Post
Should this part of the shaft be straight? YES I suspect it should be, but don’t know. A couple of books I have don’t mention it one way or the other. It doesn’t show up too well in the picture but it’s got a fair bend in it. I can straighten it after I rebuild the ball, if need be.
I understand that the ball should be round but on page 115 of Jim Schild’s book “Restorer’s Model a Shop Manual” it says that the ball should be built up on the front and rear, but do not build up the sides. Build it up round, .495 to be exact.
Tnx, Ken
While the side to side motion is less important then the front to back, Making the ball round is the way to go. With flat sides, the top of the handle will move more into your leg then if round.
Old 02-29-2016, 02:46 AM   #5
tbirdtbird
let us know how you make out
'31 180A
tbirdtbird is offline   Reply With Quote
Old 03-06-2016, 11:15 AM   #6
katy
katy's Avatar
Straightened, welded up, filed down and ready to re-install. The ball isn't perfect but methinks it's close enough. Now to get "THE SPRING" and the keeper in. Then wait a month or so until all the salt and snow are gone from the roads so I can try it out.
Old 03-06-2016, 02:29 PM   #7
jw hash
jw hash's Avatar
it looks good to me. most of them out there in Model A land are somewhat square from ware.
