Old 01-11-2021, 05:29 PM   #1
IndianapolisRacer
Default 1932 Ford rumble lid
Can you convert a 1932 Ford 3 window with a rumble seat to a trunk only model by reversing the lid thereby becoming a bottom opening trunk model ? If not is it possible to purchase a trunk and hinge setup from Brookville and will it fit the original 3 window body , I don't like rumble seats !
IndianapolisRacer is offline   Reply With Quote
Old 01-11-2021, 05:47 PM   #2
325w
Default Re: 1932 Ford rumble lid
I vote yes just get proper hinge
325w is offline   Reply With Quote
Old 01-11-2021, 06:53 PM   #3
Karl Wescott
Karl Wescott's Avatar
The lid orientation does not change (the top stays the top, bottom the bottom). You may need to cut holes and slots for the outside handle style trunk latch and handle, drill and install nut inserts for the prop, and fabricate and install the bearings for the hinge in the upper corners of the lid.
Brookvilles panels are usually close and way better then rusted out original junk, but are not perfect. Plan on some TLC to get the inner to fit perfectly, then fit and install the outer yourself.
Karl Wescott is offline   Reply With Quote
Old 01-12-2021, 09:54 AM   #4
IndianapolisRacer
Thanks , my lid is pristine so I'll take my time with this conversion , I wonder if Brookville has the hinge brackets available !
Old 01-12-2021, 10:20 AM   #5
DavidG
DavidG's Avatar
The hinges are pins and reinforcing plates and common with standard roadsters and standard coupes without rumble seats and are available in reproduction form, including from Brookville. Likely they also make the addition to the lower back panel/floor that you will need to serve as the base for the trunk lid latch and rubber lid stop bumpers.
Old 01-12-2021, 05:48 PM   #6
IndianapolisRacer
I intend to stop at Brookville once I am on the return trip from collecting the car , thank you !
Old 01-12-2021, 08:34 PM   #7
itslow
itslow's Avatar
Nothing says you have to put the seat in your trunk. You could leave out (or remove) the seat springs and riser, leaving you with a top-opening trunk.
Mike
Wanted:
- '32-34 Open Cab Pickup (RPU) parts and documents/articles/info
- ARDUN parts
itslow is offline   Reply With Quote
