04-06-2024, 03:51 PM | #1 |
1934 Closed Car Window Crank Handle
I'm looking for a new window crank handle and an interior door handle for my 34 Tudor. Have the reproductions been discontinued? Every site that I go to online says they are out of stock. I can't find exterior door handles either without the integrated lock.
04-06-2024, 06:47 PM | #2 |
Re: 1934 Closed Car Window Crank Handle
Did you contact C&G Ford Parts in California?
There catalogue shows these parts, but do not know if they are in stock. Phone number is 760-740-2400 Thanks Gary Tosel |
04-06-2024, 07:11 PM | #3 |
At this point, there is one primary vendor... Vintique. They pretty much supply every parts store. For those who like to badmouth Vintique at every opportunity these handles happen to be one of their "good" items, and it hurts when they are not available.
04-06-2024, 07:56 PM | #4 |
Karl, you make a good point. I’m one of those who has griped about Vintique. But I guess it’s like complaining about getting old. Might be bad, but still better than the alternative of no parts vendors.
04-06-2024, 08:07 PM | #5 |
Vintique has their Semi truck/trailer in the A building at the Portland Swap right Now. Newc
04-06-2024, 08:16 PM | #6 |
04-07-2024, 12:30 PM | #7 |
Thank you all for the info. I appreciate it.
04-20-2024, 01:20 PM | #8 |
Recently had the exact same issue replacing all the window crank and door handles for my ’33 Tudor. Ended up having to go to two separate vendors. Found the handles at Millworks Hot Rod and window cranks at Grumps Garage. Also ordered some new pins to go with the install.
04-21-2024, 02:29 PM | #9 |
among the now 'unobtainium' parts are the throttle choke long rods to the carb!! Found last pairs at a small dealer! Newc
