07-14-2013, 02:07 PM | #1 |
How to spot an original brake light switch?
I have tried to search for this on this forum and can not find anything on it if it is there.
What are the telltale signs of an original '29 brake light switch, compared to a reproduction? What should one look for? I assume you have to open it up to see it. Thanks!
Jim Cannon Former MAFCA Technical Director "Have a Model A day!" |
07-14-2013, 08:37 PM | #2 |
Re: How to spot an original brake light switch?
Look for brass bushings in each end of the switch, where the rod goes through. I know the 30,31 are like that.
07-14-2013, 10:04 PM | #3 |
I don't believe the '28-'29 switches have brass bushings.
I have not seen a repro '28-'29 switch, but I have an original Ford switch on my '28 coupe. I don't think you'd need to open one up to tell a repro. For one thing, a repro would not have the patina of an 80 year-old switch; even a NOS switch would have some dulling of the tin-plated case... Based on my assay of the off-shore repro headlight sockets, I would bet that the repro stoplight switches are made from much lighter metal than the original switches. If A & L makes a stoplight-switch for '28-'29, I would feel confident that it is equal to ( or exceeds ) the original Ford part. |
07-14-2013, 10:49 PM | #4 |
Here are 3 pictures showing my original 28-9 switch that I had to replace a broken spring on. I have seen some repro switches that had a thinner rod.
07-14-2013, 11:34 PM | #5 |
07-14-2013, 11:41 PM | #6 |
Oh, one other thing: originals work, and the repros... well, not always. By the way, I never push the little tabs back flat; I just give them a slight twist. This will hold the cover on and you don't risk breaking the tabs off with repeated disassemblies.
07-15-2013, 12:15 AM | #7 |
This is all very helpful, guys, especially the pictures. Thanks. It looks like my switch is an original. I will clean it up and try to get it working again.
07-15-2013, 08:39 AM | #8 |
Put a Re-pop next to an original & try pulling the plunger rod on each, you will know real quick which is which...
07-15-2013, 08:48 PM | #9 |
Ray is correct on the fiber washers. Repops are usually red. The small hex nuts on original studs are also single chamfered. Repops nuts are double-chamfered.
07-15-2013, 09:07 PM | #10 | |
Jim. I thought we looked at yours and the insulators were not correct size? Is this the same one?? |
07-15-2013, 10:13 PM | #11 |
No, I picked up another one that appears to be real (finally).
It has the smaller fiber insulator washers that are tan color, not red, and the steel nuts are correct.
07-16-2013, 09:49 AM | #12 |
Morning....* btw..these insulators are Red*
07-16-2013, 10:35 AM | #13 |
I just called A&L last week looking for a good 28-29 repop switch. They told me that they only make the 30-31 brake switches and they sell the Vintique 28-29 switches... I ordered one of them from A&L. Great quick friendly service...
My old repop 28-29 last switch failed because the red insulator seemed to be too small in diameter to work even after trying to tweak the brass contacts. I also had to use a small turnbuckle to make the correct distance link to the brake clevis pin. The new repop one is now installed and good for now but don't know how it will perform for the long haul.... Also the new link I got from A&L also fits perfectly so I was able to toss out the turnbuckle..... I also added the extra brake pedal return spring for good measure.... No more worries for now about a stop light being on all of the time.. |
07-16-2013, 01:17 PM | #14 | |
07-26-2013, 07:13 PM | #15 |
Here's a cutaway view of a repro 30-1 brake light switch. Notice that it has combo screws rather than slotted screws, and it has no bushings for the shaft.
I took this picture at the new Model A museum in Hickory Corners, Michigan. |
07-27-2013, 02:40 PM | #16 |
My repro 28-29 brake light switch failed from the end of the rod that does not attach to the linkage coming inside the switch body. Took some brass tubing and soldered it on the end of the switch body that the rod came in on. Switch works great now. Sometimes you have to make do with what you have.
Thread Tools | |
Display Modes | |
