Old 11-19-2020, 08:31 PM   #1
Habusailor
Habusailor's Avatar
Default 60hp engine
I ran across a 60hp block. No intake or heads, water pump housing has one motor mount broke off, no main caps or crank. I have the pistons out, will pull the valves next, and then cam. I don’t think it is worth trying to round up all the parts, but once the block is stripped I can have it checked out if someone is a 60hp rebuilder or someone interested in the block. I am open to any ideas
Habusailor is offline   Reply With Quote
Old 11-20-2020, 07:40 AM   #2
tubman
tubman's Avatar
Default Re: 60hp engine
Is it a "tin-side" or conventional block?
Old 11-20-2020, 08:28 AM   #3
Habusailor
Habusailor's Avatar
Conventional block
Old 11-20-2020, 08:44 AM   #4
L-head
37-39 60hp blocks use the same size main brgs. 40 60hp blocks use a larger size main brgs. You may be able to identify the year of the block by the number on the rods as they are larger also. I think the rods are marked 92-XXXX. Without the main caps, the block would probably need to be line bored, if the correct caps could be located.
L-head is offline   Reply With Quote
Old 11-20-2020, 12:22 PM   #5
Charlie Stephens
Be sure to check the market before you spend too much time or money on it. I think the only market is for restoring boats and race cars (maybe motorcycles) and I therefore believe the market is very small.
Charlie Stephens
Old 11-20-2020, 03:44 PM   #6
Ol' Ron
Ol' Ron's Avatar
The best 60 HP engine is the 1940, it had many improvements. I think they were able to tell you. I know the crank is different.available in late 39, but someone that is more familiar with them should be
Gramps
PS Isky makes a track cam that works pretty good on the street. Can't remember the number, it's been awhile.
Old 11-20-2020, 11:15 PM   #7
Lanny
Lanny's Avatar
I just sold a 1940 Ford V/8 60 this summer.
It had been professionally rebuilt, complete
and ran good.
Sold it for $1500, and the guy was going to
install it in a small 50's Ford tractor.
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
Lanny is online now   Reply With Quote
Old 11-20-2020, 11:23 PM   #8
tubman
tubman's Avatar
Damn, Lanny; next time you have one of those, call me!
Old 11-20-2020, 11:38 PM   #9
GB SISSON
GB SISSON's Avatar
I remember as a kid the v8 60 was very popular in hydroplane racing. We have some old 8mm movies of them racing on Green Lake which is pretty much downtown Seattle. Can you imagine what the Seattle of today would think about the noise, smoke and Danger of a bunch of WW2 vets racing around in a circle in their beloved duck pond? Ain't gonna happen these days. And don't get me started on the Allison and RR boats on the big lake.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson)
Old 11-21-2020, 12:32 AM   #10
Lanny
Lanny's Avatar
Hey Denny, Below is a link to my AD back in late winter of this year.
Sold the trans to a member here on the 'Barn way out on the east coast.
But I finally sold the engine to a guy down close to Iowa, that was
going to put it in a old Ford tractor. Sold it on Craigslist.
If I hear of anyone that has a good V/8 60, I will surly get a hold of you.
https://www.fordbarn.com/forum/showthread.php?t=275845
