12-28-2014, 08:17 PM | #41 |
Re: Fuel line flare
When I do choose to use any teflon, such as on a rad. hose barb on a modern car like a SBC i get the kind that comes in a tube, and use it very sparingly. The tape can be very troublesome.
Tom Endy has a unique situation of removing the fuel line often because he tests many many carbs Tom W's way of making a ferrule seal again by tinning on a layer of solder is actually very creative, but soldering is a skill not all have mastered. But everyone on here is correct: the threads of the brass nut do not account for any sealing at all; so no sealer belongs there
'31 180A |
12-28-2014, 08:21 PM | #42 |
Re: Fuel line flare
i also use liquid teflon and pretty much never tape on various applications but never on a compression
12-30-2014, 09:26 AM | #43 |
Re: Fuel line flare
The ferrule seats in two locations; on the gas line and inside the carb. If the seat inside the carb is dirty or miss-shaped fuel will leak around the threads. I use a Dremel bit (911) to clean and reshape the seat.
http://MODELABASICS.com/ How Things Work on a Model "A" Ford Fordbarners, Feel free to use the pictures on my site to answer questions and create tutorials/tech articles. |
12-30-2014, 01:57 PM | #44 |
Re: Fuel line flare
Thats good info !!! thanks for posting .
11-03-2020, 11:33 AM | #45 |
Re: Fuel line flare
In order to prevent leakage, did anybody buy the oversized ferrules from Brattons ?
11-03-2020, 02:31 PM | #46 |
Re: Fuel line flare
I know the voices aren't real but damn they have some good ideas! |
11-03-2020, 03:56 PM | #47 |
Re: Fuel line flare
Who would have guessed such a simple task could require over 40 posts. If you must use a joint sealer, google "Gasoila E-Seal". Specifically for E10 and E85 fuels.
11-04-2020, 11:33 AM | #48 |
Re: Fuel line flare
If the ferrule is not compressing around the fuel line and into the seat in the carb/fuel bowl and nut, no amount of sealer is going to help. The thread on the nuts is straight not tapered and only holds/compresses the ferrule to make the seal. We clean the seat in the carb/fuel bowl using a ball type, but gets to same place. Those areas need to be clean to seal. More often then not, just needs a light clean to seal.
