Old 03-07-2018, 08:52 PM   #21
kimeccles
kimeccles's Avatar
Default Re: Brasswork's Radiator
I have a new Brassworks for 1930 and can't get the radiator cap on. Not close to original as my original cap is mint and even an aftermarket one I bought to try, also did not fit. No successful support and even they can't find a cap that fits and looks right. I can't drive it as no cap...without Dremel tool and cutting it down some, etc.
68B frame# late May1930, fixed seat, Briggs build plate# & most parts, indicate July, or early Aug. 1930.
kimeccles is offline   Reply With Quote
Old 03-07-2018, 10:47 PM   #22
pbishop
I have had mine for two years now. Does a GREAT job here in Tampa Florida (using 4 blade fan and NO coolant - no concern over freezing here). Never has even come close to overheating. Reached 200 degrees last July waiting in slow traffic for 30 minutes or so.
Had one problem when first mounting on my 31 coupe. Radiator shell holes did not match up just right. I had to ream out the mounting holes on the radiator about .075" to mount the shell.
Use distilled water and change out when it starts to look dirty - should last and last.
pbishop is offline   Reply With Quote
Old 03-08-2018, 11:39 PM   #23
Mike V. Florida
Mike V. Florida's Avatar
Many, many, many, people have said the same thing. Brassworks stated to them that the neck is made 100% to Fords drawing. Guess all those that have posted here in the past (as well as you) are wrong.
Old 03-09-2018, 05:01 PM   #24
duke36
Some of the vendors caps with the straight tangs don't fit well and/or the gasket is too thick for the '30 neck.. One repro. st. steel was procured (can't remember where) with the curved tangs and a little vaseline and good to go. Do an internet search and have the vendor provide a photo of the cap back. I believe it's similar to the Stant profile in the Jud. Stds..
Old 03-10-2018, 03:55 PM   #25
kimeccles
kimeccles's Avatar
Yes many people have this issue and get out the Dremel tool. as opposed to sending back or other options like recore the original which is probably best idea in hindsight.
However I have a $600+ radiator with no cap that fits yet as I am trying to figure out what to grind out and sure do not want to have to remove it and mail it back for $100+.
My original cap has correct gasket thickness and is flat blade. I did try the curved blade aftermarket and it does not go all the way on.
NOTHING fits this one they sent to my Antique Auto supplier without grinding off excess at the cap which I have yet to do. Try to find a good original top and bottom and recore is my recommendation.
Old 03-10-2018, 06:35 PM   #26
hazelhoff
hazelhoff's Avatar
Berg's radiators may be fine, but they are FAR FROM original ! Only three rows of tubes instead of four, flat tubes instead of round ones. I didn't the number of fins for correctness.
hazelhoff is offline   Reply With Quote
Old 03-10-2018, 07:19 PM   #27
DJ S
DJ S's Avatar
I've considered this option before but where do you purchase a new core??
DJ S is offline   Reply With Quote
Old 03-10-2018, 09:04 PM   #28
kimeccles
kimeccles's Avatar
Some local shops can order cores. Also in addition to Brassworks, there are Model A radiators by Berg's AND Bert's radiators.
Old 03-11-2018, 02:26 AM   #29
Tom Wesenberg
Tom Wesenberg's Avatar
I bought my Berg's core about 12 years ago, and at that time they were the only ones making exact replicas of original 28-9 round tube radiator cores.
If they aren't correct now, then things have changed.
