06-23-2020, 07:41 PM | #1 |
Split rim, wide 5?
I came across a pair of wide 5's I've never seen before, is anyone familiar with the model and year truck that utilized them?
Would jalopy/dirt track cars have used them? Dimensions are 16" x 5" Thanks |
06-23-2020, 08:11 PM | #2 |
Re: Split rim, wide 5?
That’s an odd one all right, I’ve never seen one. But I would assume as you did that it was for a big truck use.
06-23-2020, 08:25 PM | #3 |
take a closer look but i will bet the wide five centers have been re-rimmed so better radials can be used
06-23-2020, 08:39 PM | #4 |
But who would choose a multi piece rim to run radials? OK, maybe a heavy truck enthusiast like myself. There was a 3/4 ton starting in maybe '39 that used 16's with a full floating axle. Maybe from one of those? I do think tey were wide 5.
06-23-2020, 08:42 PM | #5 |
I think truckdog62563 mentioned one time they were military.
I have a set marked Goodyear L.S.T. 1-44 5.50 F 16 |
06-23-2020, 09:00 PM | #6 |
06-23-2020, 09:12 PM | #7 |
I had a 1941 Ford 3/4 ton many-many years ago and it
had 16 x 5, wide 5, regular steel wheels all the way around. .
If mama ain't happy, ain't nobody happy. But if daddy ain't happy...RUN |
06-24-2020, 01:43 AM | #8 |
They do look like a factory made wheel but, a question might be, what factory, as in after market.
I would say that, because of the off set, they maybe for, rear axle only use, maybe even a trailer? If they came from Ford, I would, also go with a military application. Other than that, a odd, low/limited production, commercial. More questions than answers!
Frank '35 Ford Model 51 '48 Ford F3 '54 Ford Tudor Mainline |
06-24-2020, 02:33 AM | #9 |
Thanks for the replies, some interesting data provided, I appreciate it. At first I thought they were home made but the quality of work (rivets hold the centers to hoops) ruled that out.
The wheels came with very old military tires mounted, I believe I do have photos somewhere... if I can locate them, I'll share them here. Ive seen more 18" wide 5's than split rims, this pair is the first I've seen in 25 yrs which is why I posted them here. I bought them thinking they were 15" 3/4 ton wheels, but the seller and myself neglected to read the tire markings and frankly I thought they were 15" until I had the tires removed. |
06-24-2020, 07:57 AM | #10 |
Searched the books but don’t find it. The Goodyear split ring/rim combined with the wide five pattern isn’t listed anywhere. Probably means it was a military wheel which didn’t normally appear in civilian references until many years later. Even there I didn’t find it in later years listings. Kinda in the same category as that mentioned 16” x 5.5” Dodge/IHC military wheel having the Goodyear LTS rim. Dated 1944 but was the 1950s before they appeared in Budd listings. Stu
Stu McMillan Marmon-Herringtons |
06-24-2020, 08:05 AM | #11 |
The 3/4ton rims was a bit different in design to the slots are a bit less wide i think ?
I have 2 real nice 3/4ton wide 5 that came with a dirt track...only when side by side with a normal the design difference is clear. |
06-24-2020, 11:38 AM | #12 |
I have one of the split rim wide 5 wheels as well. They are not 39-41 3/4-ton, as those are 16x5 and 16x5.5 standard drop center rims. Those wheels do look like they used the 3/4-ton center.
06-24-2020, 09:22 PM | #13 |
Neal - yah, the centers led me to think they were the 3/4 ton variety. Where did you pick up your split rim? I believe mine came out of the central coast.
Some additional photos of the wheels with tires mounted. |
06-24-2020, 11:07 PM | #14 |
Hi; appears to be an outside edge locking ring and those are safe. All my military trucks use them. There were Marmon-Herrington 4wd '39 wagons made for the British in WW2, as well as 40/41 wagons. A selection of those wheels sold at the Portland Swap 2 yrs ago; snapped up by some 'Downunder" fellows. Newc
06-25-2020, 11:05 PM | #15 | |
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) Last edited by GB SISSON; 06-26-2020 at 09:20 AM. |
06-25-2020, 02:36 AM | #16 |
Thanks for the information Newc, you wouldnt happen to have some images of the wheels in use?
06-25-2020, 09:58 AM | #17 |
I have 3 wide 5 split rim wheels that are similar, but different to the ones posted in the pix. The wheels I have, have the split ring on the inside portion of the wheel.
I have a big interest in early 4x4 vehicles. Anytime I see an EFV8 4x4, pickup, car or station wagon I stop and look it over. I know where there are two '46-48 Ford club coupes in Montana that are Marmon-Harrington 4x4, both vehicles were bought new by the current owners of the vehicles. The wheels on the coupes are the 36-39 wide five which I have read MH continued to use through '48 on their 4x4 conversions. I would make a WAG that the split rim wheels were made by an aftermarket manufacture and therefore do not show up in the Ford parts books. The wheels I have came off of a '37 pickup that I bought as a parts truck, ergo 3 wheels, which I parted out for a '37 pickup I was rebuilding in the mid '60's. I have had the wheels for over 55 years.
Bill.... 36 5 win cpe |
06-25-2020, 07:07 PM | #18 |
I had a pair, Homemade, was told it was an outside set of dirt track wheels. Don’t think I still have them, they were not perfect straight, and heavy
How bad do you want to make that outside pass and risk eating the split ring? Nah, I understand the theory of “ low un-sprung weight |
06-26-2020, 03:19 AM | #19 |
I wouldn’t have been able to help, Gary. Except to confirm they are special. The Marmon-Herrington connection here interests me too. Wheels like this now show up for which there is no reference, and conversely I have references for Marmon-Herrington wheels that no one has ever seen. Sometimes the more you know on a subject you learn that there’s a lot you don’t know. Stu
06-26-2020, 10:22 AM | #20 |
I have a pic in my collection of early Ford trucks that shows a '37 Ford 4x MH. The article attached to the pic says the truck was special built for an oil company for use in the middle east.
The basis for the truck was a 1.5 ton chassis, shortened to 1 ton with MH suspension and running gear. The bed was from a pickup, tires appear to be General Jumbo's on Ford type wheels/hubcaps. The truck is really cool looking, looks like a modern 4x, however the pic was taken in '37. I have attached a few pic's of EFV8 MH 4x's If you look very closely at the '42 MH 4x pic you can see the 36-37 style of hub cap on the L Front wheel.
Bill.... 36 5 win cpe Last edited by blucar; 06-26-2020 at 10:31 AM. |
