Old 07-06-2015, 01:20 AM   #41
Henry1953
Henry1953's Avatar
Default Re: Removing rear brake drum
I had to heat mine as in #35. They both came off and no damage to threads etc.
Henry1953 is offline   Reply With Quote
Old 05-11-2016, 05:37 PM   #42
John Borland
Thumbs down Re: Removing rear brake drum
I am also having a problem pull the rear hub. My question is: how do you keep the rear hub from spinning around when you tighten the hub puller? I put the tranny in gear, but the hub still spins. (As a side note, yesterday I installed a new transmission tower section; perhaps I don't have it installed correctly thus permitting the hub to spin - I will check on this also).
Also the hub puller I am using is similar to the K. R. Wilson, but forms only half a circle around the recess rather than a full circle. Thanks for any help anyone may have.
John Borland is offline   Reply With Quote
Old 05-11-2016, 05:47 PM   #43
Tom Wesenberg
Tom Wesenberg's Avatar
Pulling the parking brake on should stop the drums from spinning. Otherwise have the tire on the ground for the other rear wheel, and have the tranny in first gear.
Old 05-11-2016, 05:49 PM   #44
John Borland
I am also having a problem pulling the rear hub on a 1931 Model A using a half shell puller. One of the problems is that the hub spins when I try to tighten the tool despite having the car in gear. How can I prevent it from spinning since the e-brake is supposed to be off when removing? (I might mention that just yesterday I installed a new tower assembly to my transmission; perhaps I screwed up on that somehow - will recheck that).
Old 05-11-2016, 05:57 PM   #45
Rowdy
I broke my bell shaped puller last week after several years of use. Ordered the improved KRW style puller and should have it late next week. When I have one that tries to spin like you discribe, I put the lug nuts on and wedge a tire iron or piece of pipe between two of the studs with the end on the ground to keep it from spinning. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!!
Rowdy is offline   Reply With Quote
Old 05-11-2016, 06:03 PM   #46
Pilotdave
Pilotdave's Avatar
Re: stopping the drum from spinning - x2 like Rowdy said.
Pilotdave is offline   Reply With Quote
Old 05-30-2016, 09:49 AM   #47
qstott
qstott's Avatar
Is it ok to user an impact driver or wrench on the puller bolt?
qstott is offline   Reply With Quote
