Old 03-14-2015, 01:06 PM   #1
capt280
Default Quick Flathead question for everyone
Will a T5 transmission for a ford (unknown year) work on a 8BA Flathead. Seems what i have been reading is the S10 T5 is the go to choice.
Thanks in advance for everyones help
capt280 is offline   Reply With Quote
Old 03-14-2015, 01:36 PM   #2
rotorwrench
rotorwrench's Avatar
Default Re: Quick Flathead question for everyone
I believe that the difference is the location of the shifting mechanism. The S10 is farther forward than the mustang type.
rotorwrench is online now   Reply With Quote
Old 03-14-2015, 01:48 PM   #3
V8 Bob
V8 Bob's Avatar
The late '80s/early '90s Mustang W/C T-5 is a better choice over an S-10 because of better ratios, internal improvements and higher strength, but the S-10 tail housing swap moves the shifter forward and next to the gear box. A 1" adapter will mate the trans to any '49-'53 Ford/'51-'53 Mercury bell housing.
V8 Bob is offline   Reply With Quote
Old 03-14-2015, 04:22 PM   #4
JSeery
JSeery's Avatar
Almost, you need the half-bell and the hogshead plus the adapter plate or a half-bell and one of the aftermarket cast adapters.
First photo is an aftermarket cast adapter
Second photo is half-bell, hogshead & 1 inch plate adapter
Third photo is line drawing using a half-bell and aftermarket cast adapter
Forth photo is half-bell, hogshead, 1 inch plate adapter & S10 T5
Old 03-14-2015, 04:34 PM   #5
rodderbilly
rodderbilly's Avatar
Hi..i'm in the way to put Ford t5 on my potvin powered flathead,,and i see that there are other ways to put the shift level forward,,,a remote lever mechanism is the right way,in a mustang web page there is one type for sale....other easy way i try is to buy a opel corsa c shift lever.....or at least is not really difficult to build one yourself......
rodderbilly is offline   Reply With Quote
Old 03-14-2015, 07:39 PM   #6
V8 Bob
V8 Bob's Avatar
Originally Posted by JSeery View Post
Almost, you need the half-bell and the hogshead plus the adapter plate or a half-bell and one of the aftermarket cast adapters........
You just need this 1" adapter for a Mustang T-5 to bolt to the '49-'53 Ford/'51-'53 Mercury bells. A '51 Mercury is the one shown and is what I'm using in my avatar.
Old 03-14-2015, 08:44 PM   #7
hotrodcbx
Definitely go for the late model Mustang. Better ratios and MANY improvements over the S-10.. I have used the 1" adapter plate but for my current build I am using a Quick Time bellhousing from Speedway Motors. Not cheap ($570.00) but I believe it will hold the critical engine to trans alignment more accurately..
hotrodcbx is offline   Reply With Quote
Old 03-14-2015, 08:54 PM   #8
JSeery
JSeery's Avatar
V8 Bob you are correct! I was thinking the earlier years 8ba Mercs and trucks. I am going to have to slow down on my reading!!!
I like the remote shifter using the original shifter location and shifter. That's what I am using with a Ford T5z transmission.
Old 03-14-2015, 09:45 PM   #9
Ross F-1
Ross F-1's Avatar
I think this is what was meant by a remote lever
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 03-14-2015, 09:49 PM   #10
Ol' Ron
Ol' Ron's Avatar
V8 Bob
Where did you get that adapter, I've been making them, but this is a better and cheaper way to go
Old 03-15-2015, 07:34 AM   #11
V8 Bob
V8 Bob's Avatar
Originally Posted by Ol' Ron View Post
V8 Bob
Ron, I bought my adapter from Mark Kirby (MCF) about 15 years ago. They may still be available from him at Shadow Rods, and are from Modern Driveline, below.
http://www.safepay.net/cgi-bin/shop/...oderndriveline
Old 03-15-2015, 11:16 AM   #12
JSeery
JSeery's Avatar
Believe Wilcap has them. V8 Bob what years of the bellhousing has the cross-shaft clutch fork setup?
Old 03-15-2015, 11:46 AM   #13
V8 Bob
V8 Bob's Avatar
The major production '51 Mercury bell housing was the only year for the '40-'48 cross shaft clutch release. ( JFYI, I'm using a '32-'39 cross shaft in the one pictured.)
A few early '51s used the '49-'50 stamped steel 1/2 bell and round patterned transmissions.
Old 03-15-2015, 02:48 PM   #14
Ol' Ron
Ol' Ron's Avatar
That adapter works with the 49-53 Ford and Mid 51 merc bell housings using all stock parts except the disk.
Old 03-15-2015, 03:00 PM   #15
JSeery
JSeery's Avatar
I had never seen one, didn't know they existed! Thanks.
Thread Tools
Display Modes
