09-23-2021, 11:53 PM | #1 |
How the heck to I get my top down????
My 36 Club Cabriolet came in today and I can't seem to figure out how to fold down the top. I picked up the little "Instructions for lowering and raising top" book for the Club Cabriolet and my top seems to be different. Most likely a after market top. Anyone have knowledge of these after market tops?
09-24-2021, 12:12 AM | #2 |
Re: How the heck to I get my top down????
Without pictures, all you're likely to get is smart ass answers!
Alan |
09-24-2021, 12:21 AM | #3 |
A guy walks into a bar, says "how do I get my top down"..............
09-24-2021, 12:22 AM | #4 |
09-24-2021, 01:28 AM | #5 |
Beautiful car, Chris. Your top frame is stock, the top material has been replaced. Don't try lowering the top without help, preferably experienced help. Even then, you may damage the top or injure yourself trying.
Lower the rear window to the top well. Release the two side tensioners. Release all button fasteners. Release header from windshield, lift just off the pegs. Release/remove side fingerscrews to allow the frame elbows to fold inward. Do not proceed without help.
Alan |
09-24-2021, 06:40 AM | #6 |
09-24-2021, 07:45 AM | #7 |
As I recall, on an original top, undo any snaps or attachments each side of the rear lower portion of the roof.
Sitting inside the car disconnect the front latches and push up and towards the rear near the center of the bow. ( never needed two people to do the operation)
DON'T RECALL DOING SOMETHING FOR MYSELF BASED ON SOMEONE ELSE'S LIKES OR DISLIKES Last edited by 51 MERC-CT; 09-24-2021 at 07:50 AM. |
09-24-2021, 07:48 AM | #8 |
Robert, If you are expecting it to be as easy as the instructions might lead you to believe, well, don't believe them. I have a 36 roadster that I do lower the top on occasionally by myself. I am willing to bet I go from one side to the other at minimum 6 times.
09-24-2021, 08:40 AM | #9 |
Robert, Is this the instruction book that you have? You don't want the one for the regular Cabriolet.
09-24-2021, 10:27 AM | #10 |
Nice looking car. I wonder what happened to the vacuum cylinder can
on the Columbia? |
09-25-2021, 10:40 AM | #11 |
Lowering the top on a convertible can be a time consuming chore. If the top has not been lowered for some time, or ever, the folds are likely random, not allowing them to fall between the top irons as the slack appears. Of course all side snaps must be released before starting. As you lower the top, place the folds as set out above so the irons will fall into place. Having someone on each side make it easier, with fewer trips around the back of the car. This all assumes that the top and pads were correctly installed, and the movable bows are free to move.
09-26-2021, 11:28 AM | #12 |
First let me congratulate you on a real Beauty, love the look! As said as it sounds like you’ve not done before so get a couple guys to help, preferably one that has done before. While I do know several friends with older ragtops & i love them & had a a few they are a PIA for top take down / put up! You will get there but as with most guys I know with the older ones thru the early ‘60’s I’ll bet like me & them eventually you’ll keep in side with tops down during the season except when washed & to keep sized. Then up in the off season to keep stretched to size. I know fiberglass lift offs are available for some Early Ford roadsters ( street Rod applications). Guys I know keep the smaller ‘convertible interior covers’ to protect if rain ensues (obviously can’t drive with it) or to keep sun off interior. I have one for a late model Ride of mine. BOL with a very sharp Ride!
Nomad |
