Old 08-02-2021, 01:10 AM   #1
dean333
dean333's Avatar
Send a message via Yahoo to dean333
Default 34 starter cable color
What color should the cable from the solenoid to the starter on a 34 be? Thanks!
Tim Carlig
dean333 is offline   Reply With Quote
Old 08-02-2021, 03:30 AM   #2
koates
Default Re: 34 starter cable color
The original heavy gauge 6 volt starter / battery cable had rubber insulation with braided or woven cotton covering over the top which was black. It is reproduced today. Regards, Kevin.
koates is offline   Reply With Quote
Old 08-02-2021, 06:56 AM   #3
David J
David J's Avatar
Solenoid on a 34 ??
David J is offline   Reply With Quote
Old 08-02-2021, 08:30 AM   #4
DavidG
DavidG's Avatar
As David J asks, what solenoid? Originally, there was one cable (black) from the battery to the starter switch and another from the switch to the starter motor (also black, same material for insulation as Kevin describes, and same bundled wire inside) with no solenoid in between.
Old 08-02-2021, 03:11 PM   #5
Bored&Stroked
Bored&Stroked's Avatar
In addition to the starter cable, there are a couple cable routing brackets that bolt to the engine/transmission bolts with big rubber grommets in them (at least I believe they used them in 34). They are used to route the cable from the switch on the steering column over to the starter.
Old 08-02-2021, 03:15 PM   #6
DavidG
DavidG's Avatar
Bored&Stroked,
Yes, all '32'34 V8 used those brackets with the big grommets except for the RHD versions where the cable is much shorter.
Old 08-02-2021, 03:25 PM   #7
dean333
dean333's Avatar
Starter solenoid
File Type: jpeg 97F0B6C5-C3D0-4208-8B06-2299C7AD38ED.jpeg (41.1 KB, 26 views)
Tim Carlig
Old 08-02-2021, 03:54 PM   #8
DavidG
DavidG's Avatar
Just the ticket if you have a '37 or later Ford as they weren't used by Ford prior to the '37 model year. In fact, the one in your photo is the '40 version with an O1A part number prefix.
If you are using one, you'll have to measure to determine how long a cable you will need and then off to the NAPA store to see if they have one of the heavier 6 volt cable variety in the length that you need.
Old 08-02-2021, 04:01 PM   #9
51 MERC-CT
51 MERC-CT's Avatar
Perhaps the '34 was converted to a later configuration, only the owner knows.
So any information for the '34, for the most part won't apply..
Old 08-02-2021, 04:47 PM   #10
34PKUP
34PKUP's Avatar
Originally Posted by dean333 View Post
Starter solenoid
Do you in fact have a solenoid or the original starter switch on the floor?
34PKUP is offline   Reply With Quote
Old 08-02-2021, 05:01 PM   #11
dean333
dean333's Avatar
Push button on the dash and solenoid as pictured on the firewall. Also has a 59 AB engine.
Tim Carlig
Old 08-02-2021, 05:36 PM   #12
Kube
Kube's Avatar
So, to answer your original question: The cable can be any color you prefer as you do not have a stock vehicle.
Old 08-02-2021, 06:45 PM   #13
DavidG
DavidG's Avatar
Would have been too much trouble to state the information you provided in #11 in your original post?
Old 08-02-2021, 07:17 PM   #14
34PKUP
34PKUP's Avatar
So you do not have a stock '34, as previously stated you can make it any color you want.
Old 08-02-2021, 11:16 PM   #15
dean333
dean333's Avatar
Jeez David, lighten up. I didn’t know solenoids and dash push buttons weren’t stock on a 34. So much sarcasm today.
Tim Carlig
Old 08-03-2021, 09:42 PM   #16
Bored&Stroked
Tim does have a point . . . we all tend to get up on our "here is perfection" pulpit (just did it myself yesterday) - we need to relax and remember that we've all acquired or sold cars that are a far cry from 'factory original' - and in some cases, they've been improved.
Thanks Tim Craig!
Old 08-04-2021, 04:54 PM   #17
JSeery
JSeery's Avatar
Hear ya, BUT, it is interesting how many questions are ask that ends up being something enterally different from what their first post would indicate. Like an ignition question and you end up finding out it's converted to 12v with a different coil and a latter key starter switch. It just helps if we know what we are really dealing with when we attempt to provide an answers.
Old 08-05-2021, 11:32 AM   #18
dean333
dean333's Avatar
To clarify my intent….I know some things aren’t exactly as they left the factory. However I try to make things as correct as possible so I don’t have a hodgepodge mess of stuff. Hence, I merely wanted to know what color the cable was SUPPOSED to be in 34. Doesn’t matter to anyone else what’s been changed. A simple answer was “black, red, white or whatever.” Anyway, black sure looks a lot better than the red it was!
Tim Carlig
Old 08-05-2021, 01:36 PM   #19
B-O-B
B-O-B's Avatar
The red cable you speak of is more than likely a battery cable.
B-O-B is offline   Reply With Quote
Old 08-06-2021, 07:37 PM   #20
T Scott
Go get'em Tim! I'm with you!!
T Scott is offline   Reply With Quote
