Old 11-28-2021, 06:39 PM   #1
Shampipple
Shampipple's Avatar
Default 1939 Juice Brake Hose question.
I’m actively converting my 38 Frame with 36 Spindles over to 39 Spindles and Juice Brakes.
I bought the brake hose brackets.
Can anyone share a photo of the factory location of the hose brackets?
29 Model A Roadster, 39 Pickup, 50 Custom Tudor, 66 Mustang Fastback, 79 F350, 02 Thunderbird
Shampipple is offline   Reply With Quote
Old 11-28-2021, 07:48 PM   #2
1939mars
1939mars's Avatar
Default Re: 1939 Juice Brake Hose question.
Hope these help.
1939mars is offline   Reply With Quote
Old 11-29-2021, 01:23 AM   #3
Tinker
Tinker's Avatar
A 38 frame should have most of the holes already there.
Richard Lacey has kits. Used his for a mid frame MC 38 conversion. Went with a 39 pedal later. All the lines worked with some small MC reroute. They have all the lines wheel to wheel. If a 39 pedal version, just let them know what you are doing. Spiral rock guards... etc. Very good stuff.
http://www.earlyv8garage.net/?redirect=false
If I get around to it this work week I'll take some pictures.
Old 11-29-2021, 03:06 AM   #4
V8COOPMAN
V8COOPMAN's Avatar
Here are some pics that should head you in the right directions. DD
Looking FORWARD
Notice brake line follows each individual radius rod.
Click Links Below __
T5 W/TORQUE TUBE
Old 11-29-2021, 11:52 AM   #5
Shampipple
Shampipple's Avatar
Thank you all!
I see I’m in need of an e brake bracket as well.
Old 11-29-2021, 07:04 PM   #6
Shampipple
Shampipple's Avatar
Do any of you know if this cable bracket is reproduced?
Old 11-29-2021, 07:31 PM   #7
V8COOPMAN
V8COOPMAN's Avatar
I doubt that bracket is reproduced, but it would not be difficult to make in your garage. If you'll look at the picture below, you can see the bolt passing through the top end of that bracket. DD
T5 W/TORQUE TUBE
Old 11-29-2021, 07:44 PM   #8
Shampipple
Shampipple's Avatar
Not an issue at all. I really appreciate all of your help on this build. I am sure I can make one if I have to.
Old 12-02-2021, 05:08 PM   #9
Shampipple
Shampipple's Avatar
Thanks again fellas. It’s coming along.
Old 12-07-2021, 04:43 PM   #10
Shampipple
Shampipple's Avatar
I fabricated a bracket for the e brake cable. I appreciate seeing your photos. They definitely helped. And yes, that’s a brake hose bracket. Same diameter hole, and some stamped support in it.
