09-03-2020, 07:45 PM | #1 |
Y block big truck water pump/ fan.
We wish to raise the fan height on a Y block in a model A Ford . I have in my parts piling system a big truck Y block water pump with the ears on top for the fan . But we are unsure what the fan assembly looks like. Tried a flathead one but the assembly is too long and it has the wide pulley. I presume we need a double sheave crank pulley also?
Any help appreciated. |
09-03-2020, 07:55 PM | #2 |
Re: Y block big truck water pump/ fan.
That is an option. I would opt for a plastic fan shroud that you cut when it comes. Meaning no hole for the fan.
09-03-2020, 08:47 PM | #3 | |
I'm assuming the 2 empty bolt holes on the top surface of the (red) timing cover are to mount the fan bracket. ??? Last edited by dmsfrr; 09-03-2020 at 08:58 PM. |
09-03-2020, 10:13 PM | #4 |
Thanks @dmsfrr , thats a head start . Fan pulley sticks out further than i expected . Hopefully someone has a head on view.
09-12-2020, 03:59 PM | #5 |
Thread Tools | |
Display Modes | |
