05-15-2020, 09:55 PM | #1 |
Fan Belt question for NZ Barners
I had a noise from the fan generator area and investigated and found my fan belt is torn. Do any of the the NZ barner have a local source for the big belt (Generator) on a 59a engine? or a part number for one that will fit?
thanks GB
"you can't make honey out of dog sh*t" "You're a long time looking at the lid" |
05-15-2020, 10:50 PM | #2 | |
Re: Fan Belt question for NZ Barners
They are a B section. Have the sizes of the 2 belts on white board at home. Will post them here when I get home later in the day. Phil NZ |
05-15-2020, 11:03 PM | #3 |
Cool Phil been looking at Gates industrial B series from web search could be a 50 or 54 length look forward to your reply. Can get Gates belts on line from Bearing engineering supplies here in NZ
05-15-2020, 11:51 PM | #4 |
I use B52 if you want a stock looking belt.
BX52 is the cogged one with a bit better power transfer ratio. The size can go up or down a bit depending on what shieve you have on the generator...but with the normar pulley for a 59AB the B52 works fine. |
05-16-2020, 01:31 AM | #5 |
Just checked, I'm using a B50 on Genr and B34 on cooling fan.
I get mine from an old style Engineering Workshop at Oxford. They still store them off hooks at wooden rafters. Phil NZ |
05-16-2020, 03:11 AM | #6 |
GB
05-16-2020, 04:24 AM | #7 |
Thanks for your help
