01-12-2020, 08:25 PM | #1 |
32 to 34 spindles
Are 32 to 34 spindles interchangeable?
Our LHD 32 has a crack in the steering arm ! |
01-12-2020, 08:40 PM | #2 |
Re: 32 to 34 spindles
To the best of my knowledge the answer is Yes
01-12-2020, 09:15 PM | #3 |
Short answer, YES. The Green Bible says part B 3105 (Spindle Assy -RH-LHD) fits 32-34 and B 3106 (Spindle Assy -LH-LHD) fits '32-'34.
Charlie Stephens |
01-12-2020, 09:55 PM | #4 |
Thanks guys, that will enable me to widen my search for one.
01-13-2020, 06:16 PM | #5 |
Found a 34 one in my stash that was RHD , so cut off the drag link arm to make it identical to a LHD RH spindle. And it wasn’t cracked .!!!
01-13-2020, 07:00 PM | #6 | |
REAL "car guys" just gotta have a stash! DD |
01-13-2020, 07:37 PM | #7 |
Short URL: http://smu.gs/14g7eDW |
01-13-2020, 07:44 PM | #8 |
Not to hi jack this thread, but here goes. If your upgrading an early A or 32/34 vehicle to a more modern rod such a Juce brakes and alittle engine mods. You might want to improve the steering, by using late 35/48 spindles and cross steering. Another sreering box bt Toyota Cellic had the input shaft over the frame and gives exhaust manafold clearance. The Chevy rag jiint fit;s the input and a Ford pitman arm fits the output. This is a vast improvement in driving pleasure. at a small cost.
