Old 10-26-2017, 08:04 PM   #1
vonpahrkur
Default V860 parts stash extravaganza-individually priced
City: Bakersfield
State: CA
Price: in ad
V8 60 parts, priced individually. All new or rebuilt parts to build an engine. I can do a little better if someone wants several things. message me with offers and questions, thanks
New Offy heads with water manifolds SOLD
new water pump internals with housing/cradle mount SOLD
Winfield 3/4 cam reground ready to go with new Timing gear SOLD
New adjustable liftersSOLD
distributor adapter to run a crab style distributor SOLD
Flywheel surfaced, has new clutch and pressure plate SOLD
New 60 over Egge pistons with pins and new rings $425
Rods with new bushings and bearing $400
New bearing set $165
Polished crankshaft with new gear $270
new best gasket set $180
nice crank pulley $40
decent used Spark plug wire tubes $50
water pump housing/front cradle mount $80
used stock lifters $85
valves and springs $175
3- V8 60 blocks:
one 1937 tin-side block. $250
one 1938-1939 iron side block with cam $350
one 1940 block with cam $350
one fully machined 1939 iron-side block with new cam bearings installed (needs repair in an exhaust port) $550
Stock crankshaft needs cleaned up $120
3-stock oil pans-$80 each
2 modified oil pan (holds additional oil, likely from an old race car) $110
Will make a package deal if someone wants to buy everything!
Also have a v8-60 truck transmission case available (top shift trans that takes 39 internals) $250
Looking for original 1932 3-window coupe parts to complete my project. Also looking for 1936 ford roadster body /parts. Lots of 1941 Mercury convertible parts for sale.
vonpahrkur is offline   Reply With Quote
Old 10-30-2017, 06:28 PM   #2
vonpahrkur
Default Re: V860 parts stash extravaganza
bump, make offer-surely someone is building a V8-60 and would like to get everything for half of what it costs new.
Old 11-02-2017, 07:26 PM   #3
vonpahrkur
bump-individually priced now
Old 11-19-2017, 01:50 AM   #4
vonpahrkur
a few things have sold, but still lots of good stuff left.
Old 11-24-2017, 02:09 PM   #5
vonpahrkur
bump
Old 11-27-2017, 06:33 PM   #6
vonpahrkur
more parts added
Old 12-03-2017, 09:11 PM   #7
vonpahrkur
More added
Old 12-13-2017, 03:59 PM   #8
vonpahrkur
Still lots of stuff available.
Old 12-28-2017, 08:45 PM   #9
vonpahrkur
bump
Old 01-09-2018, 02:19 PM   #10
vonpahrkur
please delete this ad, i created a new one since i couldn't edit this one thanks
