Old 01-06-2016, 05:39 PM   #21
Tom Walker
Tom Walker's Avatar
Default Re: 1932 torque tube length
I've got it...you need photos!!
axle
flange
front
da daaa!
Tom Walker is offline   Reply With Quote
Old 01-06-2016, 06:52 PM   #22
V8COOPMAN
V8COOPMAN's Avatar
That's cool........you guys have real, Yankee-like measurin'-sticks over there. Seriously Tom, that should tell the story without any doubt......much appreciated. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 01-06-2016, 07:22 PM   #23
DavidG
DavidG's Avatar
All that's needed now is the same dimension for the late '32 torque tube with the scalloped rear flange (given that the above is for the early torque tube).
Old 01-06-2016, 08:13 PM   #24
Bader
Bader's Avatar
Originally Posted by vonpahrkur View Post
I have two torque tubes, one is supposed to be a 1933/1934 and measures 62" long, the other is supposed to be a 32 and also measures 62" long
Looking for the following measurements so i will know for sure what i have and also so others that encounter this same thing will have a reference in the future:
Length of 1932 V8 torque tube
Length of 1933/1934 V8 torque tube
Length of 1933/1934 4 cylinder torque tube (if it's different than the V8)
Thanks in advance
The torque tube from my 34 v8 deluxe fordor is 62 inches.
Bader is offline   Reply With Quote
Old 01-06-2016, 08:16 PM   #25
JSeery
JSeery's Avatar
Looks like Tom nailed it has the photos to boot!!!
Old 01-06-2016, 08:19 PM   #26
Flatout
Flatout's Avatar
Mine, measured in dim light with a tape are:
'32 round flange. 53 3/8"
'32 scalloped flange. 53 5/16"
'34 V8. 61 15/16"
'34 4. 60 3/8"
Flatout is offline   Reply With Quote
Old 01-06-2016, 08:23 PM   #27
V8COOPMAN
V8COOPMAN's Avatar
Originally Posted by V8COOPMAN View Post
1932 T-Tube is 53-5/16".
'33-'34 V8 tube is 61-7/8".
'33-'34 4-cylinder tube is 60-11/64".
DD
If you'll note my earlier post, it shows the '33-'34 V8 torque tube to be 61-7/8". Even in Henry's book of allowable tolerances for how a torque tube fits-up, that's well-within a Royal red cunt hair's width of 62".
THIS thread has pretty-well and difinitively established the three BASIC lengths for the available torque tubes used on '32-'34 Ford automobiles of both flavors......V8 and 4-cyl. It should also be clear, and easily understood by anyone mechanically-inclined enough to understand how the TT bolts into these vehicles, that a variance in length of 1/16" to even 1/8" between different examples, will obviously still fit and function as originally designed by Ford folks. This has been a great thread, with some great input from several folks. DD
T5 W/TORQUE TUBE
Old 01-06-2016, 08:34 PM   #28
JSeery
JSeery's Avatar
Coopman, Flatout got a whole 1/16 closer than you did!
Old 01-07-2016, 04:43 AM   #29
Tom Walker
Tom Walker's Avatar
I mistakenly called my torque tube "late" because the car has a late serial number. Seems it must have hung around for a while in a crate in Dagenham!
Old 01-10-2016, 10:16 PM   #30
Andy
How much shorter is a 32 rear housing than a 40?
I get .456" longer for the 40 housing.
I have the length figured out for the new shorter 32 torque tube. It would be 52.92" The difference in length of a 34 torque tube and a driveshaft is 1.68" If the same coupling dimensions are assumed, the new 32 driveshaft would be 51.24"
The dimension I would like to get is the distance from a 34 flange face to the pin hole in the pinion shaft. That would tell me if driveshaft dimension can be used or would need to be adjusted to get the hole in the right place.
Nice puzzle!
Andy is offline   Reply With Quote
Old 03-17-2016, 05:35 PM   #31
vonpahrkur
Lots of good info here, thanks everyone!
Looking for original 1932 3-window coupe parts to complete my project. Also looking for 1936 ford roadster body /parts. Lots of 1941 Mercury convertible parts for sale.
vonpahrkur is offline   Reply With Quote
Old 03-17-2016, 06:59 PM   #32
Andy
I made my driveshaft but I knew it was not right. I went yesterday and measured three rear ends to find the clearance between the speedo gear and the snap ring. The numbers were about 1/8" but I don't know if any debris was in the way. The number that was pretty consistant was from the bell lip to the back of the snap ring groove. I make it 2.44"
Corrections appreciated!
Old 03-17-2016, 07:00 PM   #33
BoxCar Tom
BoxCar Tom's Avatar
I have an extra 32 Drive shaft (51 5/8ths) I'd like to sell, anyone interested?
BoxCar Tom is offline   Reply With Quote
Old 08-28-2023, 05:23 PM   #34
vonpahrkur
'34 V8. 61 15/16"
'34 4. 60 3/8"
can somone add the corresponding 32 scallops flange driveshaft length that goes with the 53 5/16" torque tube dimension
