Old 02-14-2011, 06:29 PM   #1
wisbangman
wisbangman's Avatar
Default 1939 windshield frame
My second post ! you folks gave me excllent advice on the first...Thanks ! I am having my windshield frame replated, but do not have a source for the replacement of the stainless piece that is in the center of the windshield or the two stainless pieces that cover where the top frame and bottom frame meet...any ideas ???.....thanks in advance....Tom
wisbangman is offline   Reply With Quote
Old 02-14-2011, 07:43 PM   #2
Planojc
Planojc's Avatar
Default Re: 1939 windshield frame
The two pieces that cover the joints are easy to make out of a piece of .030 stainless. Cut two strips 5/16 wide and form each over the top of the frame with a small hammer, and then bend the ends under. I bend one end under the frame first to hold it against the frame while I form it over the top. Cut off the excess on the ends. With a file I chamfered the edges and put a little taper from the center to each end. Polish the tops with 2000 paper. I have made several sets for the 39 and 35 and they look just like the real deal. Be sure to put a little silicone over the joint before sliding the piece over it. The center piece may be hard to find. Hope this helps
Planojc is offline   Reply With Quote
Old 02-14-2011, 08:07 PM   #3
felix37
felix37's Avatar
Tom,I believe I have an extra center strip and the two small pieces for a 39 windshield frame,I will see if I can find them if you are interested jonathan 870-847-1921
felix37 is offline   Reply With Quote
Old 02-15-2011, 05:44 PM   #4
Frank The Plumber
I may have one listed on the HAMB. Give me a PM if you need it.
Frank The Plumber is offline   Reply With Quote
