Old 11-29-2019, 06:41 AM   #1
jimvette59
jimvette59's Avatar
Default V 60 shifter
Is there a difference between the V60 shifter and the 48,78 case shifter?
jimvette59 is offline   Reply With Quote
Old 11-29-2019, 09:51 AM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: V 60 shifter
it depends on year and chassis, truck 4 speed should be same, 1940 with large trans --same, 37-39 passenger --different
Old 11-29-2019, 11:09 AM   #3
V8COOPMAN
V8COOPMAN's Avatar
Kurt....It seems (to me) that he's referencing the shifter assembly for a V8-60 (60 horse) trans case vs the full size transmission cases. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 11-29-2019, 05:39 PM   #4
jimvette59
jimvette59's Avatar
V8 COOPMAN , yes I have a shifter that looks like a shifter for the standard transmission but every thing from the pivot ball down is shorter. Jim. T.
Old 11-29-2019, 06:34 PM   #5
KiWinUS
KiWinUS's Avatar
If you need any V8/60 trans parts or shifter I probably have it..
Cheers
Tony
Old 11-30-2019, 09:02 PM   #6
jimvette59
jimvette59's Avatar
Tony could post a picture of a V8 60 trans. shifter with a ruler from the pivot ball down. I would appreciate it very much. Thanks Jim. T.
Old 11-30-2019, 10:27 PM   #7
cas3
while i am no expert, i have some 60 stuff, and was always under the the impression that there is the plain 60 trans that is noticeably smaller and uses all special components, and the commercial 3 spd trans which has the 60 bell and otherwise uses all standard 78 case parts
