Old 05-23-2019, 08:21 AM   #1
jimvette59
jimvette59's Avatar
Default Front shocks ?
How tight should a front shock be ? I have one that I could hardly move and one that has about one inch free play either way. Should the shock absorbers have play at all ?
jimvette59 is offline   Reply With Quote
Old 05-23-2019, 09:41 AM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: Front shocks ?
There should be no free play, check the fluid level, if low fill and operate to both extremes to bleed ---- properly operating it should be easier to lift arm up, very hard and slow to push down
If you look at the shock rebuilding and testing pages in the service bulletins you will get a good idea of what proper operating is
Old 05-24-2019, 09:06 PM   #3
jimvette59
jimvette59's Avatar
Thank you Kurt.
Old 05-26-2019, 02:23 PM   #4
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
If it’s repo, some aren’t re fill able
Old 05-27-2019, 11:24 AM   #5
100IH
And the unanswerable question is what fluid is in there now. Different ones shouldn't be mixed and rebuilders have their own favorites. Smell and feel is the pass word.
100IH is offline   Reply With Quote
