Old 05-04-2019, 08:09 PM   #1
37 Coupe
37 Coupe's Avatar
Default 1931 rumble seat step pad question.
Were the original step pads steel.cast iron or aluminum? If they were not aluminum were they painted black like fenders or silver color? Than You.
"Never complain,never explain"... Henry Ford II
37 Coupe is offline   Reply With Quote
Old 05-04-2019, 09:03 PM   #2
chrs1961815
chrs1961815's Avatar
Default Re: 1931 rumble seat step pad question.
I too have been wondering this because I have seen sellers advertise them as both. I checked the judging standards and my copy mentions that "Beginning in mid 1929, the step plates were black enameled, round, cast iron." It appears that production started with aluminum, went to cast iron, then back to aluminum.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 05-04-2019, 11:37 PM   #3
Mike V. Florida
Mike V. Florida's Avatar
Beginning in October 1929, through the end of production the side step was changed to unpainted die cast aluminum with a cadmium plated carriage bolt. The raven finished flat washer, lock washer and hex nut continued to be used under the fender.
Old 05-05-2019, 08:12 AM   #4
37 Coupe
37 Coupe's Avatar
I just saw a cast iron one on Ebay that is the bumper arm mount but mine is a '31. I need an aluminum one not for fender but for bumper arm, Bought one that isn't even same diameter as my cracked original one.
