Old 06-07-2019, 10:07 AM   #1
JoeCB
JoeCB's Avatar
Default GAV adjustment - how to
I usually run with about 1/2 turn open on the Gas Adj Valve, all seems to be OK at that setting. But is there a better way to make an optimum setting? Is there any reason to run richer (more open) after starting a cold engine?
Joe B
JoeCB is offline   Reply With Quote
Old 06-07-2019, 10:11 AM   #2
J Franklin
J Franklin's Avatar
Default Re: GAV adjustment - how to
Set it where it runs the best.
Old 06-07-2019, 10:56 AM   #3
100IH
There should be no effect at idle. Just as the butterfky opens it will be part of the mid range and high speed so it is changed at driving speeds. Screw it in and there will be less additional fuel= leaner. Back out the control knob and there will be more additional fuel= richer. Set it lean just short of feeling diminished performance. Just like J Franklin said.
100IH is offline   Reply With Quote
Old 06-07-2019, 12:50 PM   #4
chrs1961815
chrs1961815's Avatar
On my engine I run it more rich when it first starts up then close it a little bit when it warms. It works for me fine, it gave me a better idle.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 06-07-2019, 01:12 PM   #5
Kurt in NJ
Kurt in NJ's Avatar
I used a 4 gas analyzer with the car on a dynamometer ( the New Jersey emissions tester)to figure best setting, it is different with ethanol vs regular gasoline, on my car regular gas, full closed, on ethanol 1/4 turn till 55, then 1/2 gives leanest acceptable mixture---- and the emissions could have passed for a 2000 Honda Civic
Old 06-07-2019, 11:10 PM   #6
Mike V. Florida
Mike V. Florida's Avatar
http://modelabasics.com/carb%20basics%202.htm
Old 06-08-2019, 07:22 AM   #7
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Warm the engine, run it at a constant 25 MPH in second gear & adjust the GAV for smoothest running.
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 06-08-2019, 09:45 PM   #8
mike657894
mike657894's Avatar
thank you for this dyno tested info. I have been finding some oddness with the e10.
mike657894 is offline   Reply With Quote
Old 06-09-2019, 12:00 PM   #9
Purdy Swoft
Purdy Swoft's Avatar
It is recommended to run the Zenith one , two and three carburetors at one guarter turn off the seat after warm up . The model B carburetors should run with the GAV closed after warm up . The aftermarket pot metal carburetors usually need to run a little richer because of possible warpage and vacume leakes . Carburetors can vary and should be adjusted where they run best as said in post number two . If not running on the slow idle circuit the GAV setting will effect idle. If the GAV is set TOO rich and the carburetor isn't on the idle circuit it will lope .
Old 06-10-2019, 07:12 PM   #10
JoeCB
JoeCB's Avatar
Thanks guys. and the model basics link was very informative
Joe B
