09-04-2021, 09:59 AM | #1 |
sleeved 312 questions
Anybody on here running a sleeved 312? Any problems with over heating since the block was sleeved?
09-04-2021, 10:09 AM | #2 |
Re: sleeved 312 questions
If done right there should be no problems. I am run my Model A on the freeway and all 4 cyl are sleeved with no problems.
Mike
1930 TownSedan (Briggs) 1957 Country Sedan |
09-04-2021, 03:50 PM | #3 |
As mentioned, if done properly there is no problem and it will be the strongest cylinder in the block. Do them all if you can afford it
09-04-2021, 04:20 PM | #4 |
I have done three over the years. I fit the pistons on the loose side. About .004 to .006. Never had a problem.
09-04-2021, 10:04 PM | #5 |
