Old 05-28-2019, 11:33 AM   #1
Res731
Res731's Avatar
Default How to remove blasted carrier bearings without ruining them
I have been working on the rear diff and I knew I had to add shims under the carrier bearings due to them having spun. The machine shop had them knurled and estimated how much they took off. So I assembled the carrier with the shims and installed the bearings. Low and behold, with .046 in gaskets I still had the carrier locked up so I knew I had to remove some of the shims. I tried in vain to pull the bearing with no luck and bought a bearing splitter at HF but essentially ruined the bearing. So Im out ~50 bucks just for one side to buy another bearing and try again.
Is there some trick to getting the bearing splitter under there? I tried a 3 jaw puller but there just isnt enough to grab onto. The bearing splitter worked but it pulled on the cage and now the cage is extremely loose. So much so I woudlnt use it
Frustrated in Ohio!!
Res731 is offline   Reply With Quote
Old 05-28-2019, 11:48 AM   #2
Jim Brierley
Default Re: How to remove blasted carrier bearings without ruining them
I use what is called a knife-edge puller, and hold it tight against the back side of the bearing with a C clamp, then put in a press and push on the carrier using a socket of the proper diameter. Good luck. The cage being loose may not be a problem, it just keeps the rollers in place but no load is actually on it.
Jim Brierley is offline   Reply With Quote
Old 05-28-2019, 12:12 PM   #3
Tom Endy
Tom Endy's Avatar
I had the same problem early on. I had a friend make a small bearing puller for me that had sharp edges I could slide under a bearing hub so as to pull it of without damage if I had to remove a new one in order to add more shims.
To make it easier whenever I have carrier assemblies knurled I have the machinist take an extra cut under the bearing stop to facilitate the use of a standard bearing puller.
The attached is an article about pulling a new bearing off.
Tom Endy
Tom Endy is offline   Reply With Quote
Old 05-28-2019, 01:38 PM   #4
Res731
Res731's Avatar
HI Tom
Yes, I read the article but for the life of me I could not get the bearing puller under the bearing as you showed. The one from HF is thicker and it simple would not fit with the knife edge up. I had to install it with the knife edge down and it only connected with the cage. I tried to see if there are dimensions out there for other bearing splitters but I couldn't find anything that talks about the height (only min width, max width, bearing dimension etc.) but not actual height of the splitter .
Old 05-28-2019, 02:45 PM   #5
larrys40
As Jim said a thin bearing remover should do it. You may have to modify it slightly to fit better. I am spoiled but grateful I have a full compliment of Kr wilson tools for the job. They make quick work of it and never fail.
Be careful using 3 jaw pullers as they will not work and distort the bearing unless of course you don’t care about them.
All the best!
Larry shepard
larrys40 is offline   Reply With Quote
Old 05-28-2019, 05:08 PM   #6
Res731
Res731's Avatar
The one from HF is about 1 inch high. From a rough measurement I need a knife edge version which is no more than 3/4 -inch. Any ideas?
Old 05-28-2019, 07:42 PM   #7
Tom Endy
Tom Endy's Avatar
Mount the carrier in a vice and take a putty knife and hammer and see if you can tap it into where the bearing seats. If you can move it off the seat a little you might be able to get a screw driver in there to pry it up further. Once off the seat a little you should be able to get the bearing puller under the hub. Depends on how tight the bearing is on the hub.
Tom Endy
