07-27-2017, 04:41 PM | #21 |
Re: Throttle linkage problem.........
There seem to be a number of small items that may be contributing to the problem. The original return spring on the firewall throttle linkage doesn't even appear to be touching the arm. Can you get full throttle movement? I believe the arm should be slightly forward, yours appears to be nearly vertical. I use the same throttle arm ends and yes the return spring connection location could add to the problem. These ends could be their own problem do not tighten the adjustment screw at the end of the ends too much. Make sure they are not binding when the throttle moves. At rest you want the linkage on the drivers side to be forward and at full throttle it should be rearward as shown in posting #10 above. There are other good ideas above.
07-27-2017, 05:33 PM | #22 |
Just for fun, disconnect the linkage from the carb and try the pedal to be sure the pedal isn't binding or the pedal push shaft is not hanging up where it goes through the floor board. And while you are at it, shoot some WD40 on the shaft and spring where it traverses the firewall. If all of that is smooth, press on to the most likely suspect, - throttle plates.
- It is critical to be sure that all throttle plates are perfectly centered in the bores, laterally and fore/aft within the slots in the throttle rods. I polished the bores to smooth off any burrs in the surface. Also finely sanded the sharp edges of the throttle plates. Then, with fingers pushing the throttle plates tight closed to center them, tightened the screws that hold the plates to the shaft. Shine a light through the bore from one side and look for light shining through around the throttle plates on the other side. There should be practically no light, and if any it should be evenly spaced left and right and fore and aft. The final test is to close the throttle hard with the throttle lever, and then see if there is any binding at all when initiating opening; if so - do over! If no binding, then you can carefully ding the screws holding the throttle plates, so the screws do not back out get sucked into a cylinder. Then check again for sticking, in case you bent a throttle shaft while crimping the screws. - When fastening the carbs to the manifold the studs might allow a little slop in alignment; be sure they are centered. Maybe run a straight edge across the bases on the driver's side. - Do not yet link the carbs together. Lightly fasten the manifold on the engine and hook up the linkage to the pedal. Adjust the linkage so that with your foot off the pedal, the linkage is about 1/2" too long from aligning with the throttle lever ball on the carb. You need that much spring pressure pushing the throttle closed at idle. If there is any binding, or sticking, it is in the linkage from the firewall to the carb. - Then take the manifold to the bench and proceed to set up the linkage to the secondary (rear) carb. With the linkage not yet connected, the levers on the drivers side should be about 40 degrees forward of carburetor vertical, and as close as you can eyeball or measure to being the same angle on both carbs. At full throttle, both levers will be approximately 45 degrees to the rear of vertical. If at this point you encounter binding, let us know and we will advise further. |
07-27-2017, 05:37 PM | #23 |
SV,
Check 'weemark's' 97 setup,the arms on your carbs should be setup like that only remember the 94's work opposite. I believe the driver side arms are too vertical. On the pass side....now don't laugh, I would bend the connecting link (between the front carb and the firewall arm) so that the link assumes a more level attitude as it approaches the front carb. Subtle changes will make big improvements. With all due respect to drolston , I can assure you the throttle plates are good. As you received these carbs both were syc'd and idle speed set. Keep in mind the plates are cracked open ever so slightly to achieve idle speed. Charlie ny Last edited by Charlie ny; 07-27-2017 at 05:47 PM. Reason: 'With all due....' sentence added |
07-27-2017, 07:24 PM | #24 |
With much due respect to you Charlie, you can bend that connecting link in any shape you want. You can even bend it into a pretzel, but it will still effectively exert a pulling force in a straight line between the two existing "attach" points, exactly like it does now........simple physics. DD
07-27-2017, 09:39 PM | #25 |
Coopman......yikes......thanks for lettin' me down easy. I'll go back to Miller Lite.
I'm going bed. Charlie ny |
07-27-2017, 09:43 PM | #26 |
Charlie ny |
07-27-2017, 11:36 PM | #27 |
I've had the same problem with 94's in a dual application... I think if you try Uncle Max's suggestion it will help...however, how I got around it was to link up both carbs on both sides, ie, use a link on the regular foot feed side, use another link on the 'hand throttle' side, so that there can be no 'racking/twisting' whatsoever in any throttle position.All arms need to be same length and set up at same angles, and make the links adjustable for fine tuning, because, ultimately, they'll need to be identical lengths. I also sweat a ball midway along the regular foot feed link, and attach my throttle rod to that, which evens up the pull. Bit of fiddling about to achieve a super smooth action, but it is time well spent once it's all running good.
07-28-2017, 02:42 AM | #28 |
I think the only way you are going to get a smooth operation is to change to a cable throttle. your throttle rod mount on the pedal side is always going to be higher than he ball on the carb which means the rod is pulling at the wrong angle for it to work smoothly.
07-28-2017, 03:10 PM | #29 |
SV,
I've found a 94 throttle arm for a '49-'50 Ford with Fordomatic that positions the ball at 6 o'clock with the carb full closed and 8 o'clock full open, I think that will accommodate your issue. Get back to me [email protected] no charge. You can see the current arm is attached with a 6-32 button head screw so switching is a no big deal thing. Charlie Last edited by Charlie ny; 07-28-2017 at 03:14 PM. Reason: changed N?C to no charge |
07-28-2017, 03:23 PM | #30 | |
07-28-2017, 05:00 PM | #31 |
Email headed your way Charlie
The more I learn about new automobiles, the more I value my old ones. |
07-28-2017, 05:46 PM | #32 |
This is a typical problem with the holley, because at idle the throttle link is at 5 oclock on opening to 6 oclock the arc it travels trough means the rod in theory needs to get longer, from there on a straight pull untill nine oclock, were if it need to go further is going away again. On the original set up the return spring was on the pedal shaft and no pressure on the carb when the accelerator was pushed the little spring loaded end cap would momentarily stretch through the 6 oclock position and then close up when it had a straight pull. I would put the return spring on the accelerator pedal inside on the fire wall. Lowering the cable to get closer to a right angle[90degrees] to the throttle shaft will help, but too low you won't get full throttle. As others have said maybe a light return spring on the other side as a safety thing. If I knew how to do a sketch and post it I would as it would explain it a bit better. Hope this helps.Tony.
07-28-2017, 05:53 PM | #33 |
for purely aesthetic reasons I would change the arms on the rod that joins the carbs together on the left hand side for proper shop bought arms and use the Stromberg snapback springs(part no. 9154k) on the throttle shafts then you can remove that big spring all together - they work really well and are nearly invisible once they are installed and tidy things up no end. like the ones in the pic below
08-13-2017, 09:40 AM | #34 |
On my dual carb setup, I've noticed that with good return spring pressure on both carbs, it forces the spring loaded ends of the throttle linkage (ball mount ends between pedal lever and carb lever) to flex until they bottom out before any throttle action happens. The result is wasted motion for the first bit of pedal travel and a weird feel of lag.
That being said, I'm voting for the 5:00 position being the issue, perhaps aggravated by your throttle linkage flexing...
1932 2 door sedan/ Merc Flathead 1932 5W 1932 Roadster/ SCoT Flathead 1932 Roadster Cadillac power |
