Old 05-28-2020, 08:45 AM   #1
PeteVS
PeteVS's Avatar
Default Painting polished stainless steel
I've been painting a bunch of parts using urethane stuff including an etching primer. I doubt that an etching primer would etch stainless or anything chrome plated. Any suggestions? Thanks!
Don't never get rid of nuthin!
PeteVS is offline   Reply With Quote
Old 05-28-2020, 09:03 AM   #2
deuce5wndw
deuce5wndw's Avatar
Default Re: Painting polished stainless steel
Bead blast first.
deuce5wndw is offline   Reply With Quote
Old 05-28-2020, 09:32 AM   #3
woodiewagon46
Even with self etch primer the paint will eventually peel. As deuce mentions bead blasting is probably the easiest to get complete coverage for the primer to bond to.
woodiewagon46 is offline   Reply With Quote
Old 05-28-2020, 09:44 AM   #4
51 MERC-CT
51 MERC-CT's Avatar
I would not bead blast as it is not aggressive enough, grit blast instead.
You want to remove the shine.
Old 05-28-2020, 09:52 AM   #5
philipswanson
320 grit paper will work just fine.
philipswanson is offline   Reply With Quote
Old 05-28-2020, 10:28 AM   #6
deuce_roadster
deuce_roadster's Avatar
The "etch" part of self etching primer is to stop oxidation (rust) of ferrous metals and wouldn't likely do anything to stainless which is a high nickel alloy that does have a minimal ferrous component. As suggested, just sand it with some 320 for primer adhesion.
Old 05-28-2020, 10:48 AM   #7
DavidG
DavidG's Avatar
One of the course industrial grades of ScotchBrite will work as well.
Old 05-28-2020, 11:35 AM   #8
PeteVS
PeteVS's Avatar
Thanks. I just started attacking an old rusty crusty Model A grill shell that I also want to paint. I'm using a Harbor Freight Poly Carbide wheel. It's working pretty well on what's left of the chrome. I'll use it on the stainless as well since it leaves a pretty nice but abraded surface. I also have some garnet abrasive media that I'll give a whirl.
Old 05-28-2020, 02:42 PM   #9
doghair3
This is the stuff you might want to try.
https://www.dickblick.com/products/1...ering-enamels/
doghair3 is offline   Reply With Quote
