05-28-2020, 08:45 AM | #1 |
Painting polished stainless steel
I've been painting a bunch of parts using urethane stuff including an etching primer. I doubt that an etching primer would etch stainless or anything chrome plated. Any suggestions? Thanks!
Don't never get rid of nuthin! Last edited by PeteVS; 05-28-2020 at 09:16 AM. |
05-28-2020, 09:03 AM | #2 |
Re: Painting polished stainless steel
Bead blast first.
05-28-2020, 09:32 AM | #3 |
Even with self etch primer the paint will eventually peel. As deuce mentions bead blasting is probably the easiest to get complete coverage for the primer to bond to.
05-28-2020, 09:44 AM | #4 |
I would not bead blast as it is not aggressive enough, grit blast instead.
You want to remove the shine.
05-28-2020, 09:52 AM | #5 |
320 grit paper will work just fine.
05-28-2020, 10:28 AM | #6 |
05-28-2020, 10:48 AM | #7 |
One of the course industrial grades of ScotchBrite will work as well.
05-28-2020, 11:35 AM | #8 |
Thanks. I just started attacking an old rusty crusty Model A grill shell that I also want to paint. I'm using a Harbor Freight Poly Carbide wheel. It's working pretty well on what's left of the chrome. I'll use it on the stainless as well since it leaves a pretty nice but abraded surface. I also have some garnet abrasive media that I'll give a whirl.
Don't never get rid of nuthin! |
05-28-2020, 02:42 PM | #9 |
