07-03-2011, 08:43 AM | #1 |
Vacuum bleeding hydraulic brakes?
Hi!
I know my A should not have had hydraulic brakes, but I also know my A is not the only one with this setup. But one thing is a bit special on mine, instead of modifying the rear 46 - 48 brake shields, they are mounted up side down. Which make them a direct bolt on. This is not a result of my brain work, I just bought it this way, and now I am trying to restore the whole system to bring the car back out on to the road again, after maybe as much as 20 years standing still. Well, I put everything back in place, new master and new wheel cylinders. But I cannot get the air out of the system. I've been bench bleeding the master, no sign of air there. So I feel pretty sure the problem is my rear cylinders, since bleeder screw is now at the bottom of the wheel cylinder, not at the top where it obviously should have been. So my question is, would a vacuum bleeding system be able to suck this air out, or should I go the hard way and do some cutting and welding mods to the brake shields? I sure hope that would not be necessary, the car has been run with this setup earlier. I also read a comment, I think on H.A.M.B somewhere, where this setup was described in an earlier Hot Rod Magazine. I have heard some people telling they sometimes had to take the shields off the axle and let them lay down flat while bleeding. Doesn't sound right to me, would make a lot of stress on the brake tubings.. Is Vacuum bleeding the way to go, or doesn't it make much difference? Any comments appreciated! Last edited by Steinar; 07-03-2011 at 09:02 AM. |
07-03-2011, 10:31 AM | #2 | |
Re: Vacuum bleeding hydraulic brakes?
Removing the backing plates temporarily is one solution. Another slightly easier but potentially messier solution is to remove the forward shoe (on the right in Vince's photo since it is upside down). Pull the dust boot and piston, and allow the seal to come out of the bore at a slight angle so there is a small gap at the top. Have a helper SLOWLY AND GENTLY work the pedal to evacuate air, pushing the seal back into full contact during the pedal return stroke to prevent sucking air back into the cylinder. Joe
1929 Tudor since 1962 Feather River A's |
07-03-2011, 10:40 AM | #3 |
Very interesting! That seems to be the exact same setup! But I've been pouring 3 liters with brake fluid through the system, no air bobbles to see, but after finished bleeding, always the same, first pedal goes to the floor. The next jump on the pedal gives a rock solid one. My new mastercylinder looks pretty much the same as the old one, and this is a very common mastercylinder, used on a whole lot of different American built cars, among them also Ford. I was told. I know the problem could occur if the piston inside was not able to move enough fluid, but it doesn't seem to be any differences between them..
07-03-2011, 10:41 AM | #4 |
An old trick to bleed a cylinder with a broken bleeder screw is to just remove the outer dust shield and pop out the piston.. Then slip a about a .010" feeler strip over the top side of the cup/seal.. Wait for the fluid to start running clear and then button it back up..
07-03-2011, 10:59 AM | #5 |
If it were me I'd spend about an hour and put the wheel cylinders on top, only about 3 minor mods involved.
http://members.fortunecity.com/pjsau...ulicBrakes.htm |
07-03-2011, 11:20 AM | #6 |
would be going in the bottom and the bleeder would be on the top. |
07-03-2011, 11:28 AM | #7 |
Bob C
That was exactly what I had in mind this morning. I took everything apart, just to discover they were not symetrical, it didn't work out.. - Great minds think alike! |
07-03-2011, 01:44 PM | #8 |
If you're willing to do a bit of modification to the backing plate, they will swap from side-to-side.
07-03-2011, 01:46 PM | #9 |
Fordgarage, that is how I did it. But I can assure you I've been doing more than a couple of rounds around the car. I did put almost a gallon with new fresh fluid through the system. It is no leak to see. No bubbles visible when bleeding, two weeks since last time I saw one! I'm afraid the rear wheelcylinders are holding the air in the top of the chamber inside the cylinder. Air always want to go up, when in fluid, and pressurebleeding doesn't seem to change that. I had hoped vacuum bleeding maybe would have turned out better, sucking out the air together with more fluid coming down the tube. But I think I have learned here that this construction maybe is not the best one. It's kind a hard to fight the laws of nature. I don't know how they bled this thing when it was built, maybe they just, like you, had more luck than what I have. Or maybe they turned the car upside down, what do I know
I will think about what to do over the night, right now I feel very attracted to mrtexas' ideas, even though I also feel pretty sure JoeWays prescription also would work out fine. But like he said, a bit more messy. In the long run, I think I probably would be happier with the cylinder on top. Gives very easy maintenance. Thanks to all of you! For good ideas and pictures! I'm very impressed how fast things are working out here! Steinar |
07-03-2011, 01:52 PM | #10 |
Yes, I know, I was very close to start doing that earlier today, when I decided to first give it a try at Fordbarn. But the way mrtexas does it seems to be a easier way out, less modifications necessary, and when all comes to all, I don't really need to have'em down there. They just happened to be down there when I bought the car..
07-03-2011, 01:53 PM | #11 |
There is a real easy way to bleed that monster,, but apparently.............
07-03-2011, 02:55 PM | #12 | |
07-03-2011, 03:53 PM | #13 |
Interesting, I've also been thinking about that, let the air go out through the line-nut connection. But since this one is located about at the middele of the chamber, I was thinking I would do better, but not fully good.
I also liked the upsidedown construction in the way it was a direct bolt on, not in need of any modifications. Generally I don't like to cut in old car parts and change them unless I have to. But I have now been working on this thing for two weeks with no progress. Could it be that my cylinders are a bit different on the inside, making them more difficult to bleed when upside down? Bought them at SoCalSpeed Shop, but they were imports...? Last edited by Steinar; 07-03-2011 at 04:02 PM. |
07-03-2011, 04:01 PM | #14 |
Did you always have to bleed them through the line-connection, or was this not typical when bleeding those upsidedown cylinders?
07-03-2011, 04:15 PM | #15 |
An old mechanic told me his proceedure it is as Vince mentioned. I use a squirt oil can the type with the long tube. Force a clear plastic tube unto the long tube. Push the other end onto the bleeder Take the cap off the master cylinder. Loosen the bleeder and pump away. Works for me. Also use silicone brake fluid. My cylinders don't freeze up anymore. Tony
07-03-2011, 04:41 PM | #16 |
If you get a good firm pedal on the second pump, then you probably have an adjustment problem rather than an air problem. The old Lockheed brakes can be tricky to get adjusted properly.
Joe
07-03-2011, 08:13 PM | #17 |
I agree with JoeWay. If you get a hard pedal on the second pump, there's no air in the cylinders. Air makes the pedal spongy - every time you press it. You need to spend more time adjusting the brakes.
Doug in Waterloo |
07-04-2011, 01:20 AM | #18 |
I've done it several times exactly the way JoeWay suggests in #3. Anytime I get a car with a frozen bleeder and can't get the bleeder free, I also do it this way.
07-04-2011, 05:03 AM | #19 |
Maybe I didn't make my statement very clear, I guess thats a problem I have.. All you have to do is remove one wheel cylinder piston leaving the cup in place.. Insert a thin [about .010"] feeler strip between the top/high side of the cup and cylinder bore.. Walk away for awhile and residual line pressure will fill the cylinder and push the air past the feeler strip.. Once the fluid starts running out of the cylinder, down the backing plate and all over the garage floor, the cylinder is bled and the piston can be re-installed..
However, as has been said, the shoes should be somewhere near proper adjustment or the first pump of the pedal will just be used to push the shoes 'way out' in an attempt to find the drums.. If the pedal is 'hard and firm' then the air has been removed.. |
07-04-2011, 10:02 AM | #20 | |
Charlie Stephens |
07-04-2011, 11:07 AM | #21 | |
07-04-2011, 11:13 AM | #22 | |
I have also adjusted them until they locked all the wheels, same thing happens, but pedal doesn't go all the way to the floor then, but still too deep on the first jump after bleeding. |
07-04-2011, 11:19 AM | #23 |
I'll give it an other try, will put things back into place and bleed it like Patrick L / JoeWay suggest. If no air, it might be the mc as Charlie Stephens indicates. I'll be back when I know more. Until then, thanks to all!
07-04-2011, 11:32 AM | #24 |
I had the same problem on a 30 roadster and I bled the rear brakes just as Pat L suggusted, it works
mike |
07-04-2011, 12:57 PM | #25 | |
Charlie Stephens |
07-04-2011, 01:30 PM | #26 | ||
I see the scanned images I attached have been reduced in resolution to the point they are barely readable. Here are links to the full-resolution scans: LockheedAdjust1.jpg LockheedAdjust2.jpg Joe
07-04-2011, 04:18 PM | #27 |
Problems don't usually show up alone, do they? When I took brake parts apart at rear axle, I clamped on a special tool on the flexible tube between the mastercylinder and the front/rear connection, to avoid fluid from leaking out while parts were apart. When I had put everything back in place, I forgot to take off this clamp when we started to bleed the system again. Not much fluid come out at the rear wheel even though my helper was stepping on the pedal as hard as she could. I then remembered the clamp, took it off, but since then the pedal is stuck, does hardly move at all, no fluid is coming through the system. I guess the flexible tube got damaged, so I took it out. I could easily blow through it. So, I guess what happened is, something loosened from the inside of this not so new tubing, and found its way down into the system somewhere else, and clogged it. So I have now one more problem I'll have to look into. But tomorrow I have to prepare for my daughters birthdayparty, so probably won't be much more time for the A until end of week.
But one more question: Is it necessary to have a flexible connection between the mastercylinder on the firewall and the rest of the tubings on the chassis, or could I go with steel tubing all the way from the mc to the wheels? Does the frame twist as much under driving that it could cause stress to the brake tubes if all steel? And, yes, I measured the mc, they're both one inch diameter. |
07-04-2011, 04:24 PM | #28 | |
07-04-2011, 04:28 PM | #29 | |
Charlie Stephens |
07-04-2011, 05:06 PM | #30 | |
You have a good feel for this, obviously, and about 27% would be correct for 1-1/8" vs. 1", but the '39-'48 Ford car and light truck master is indeed 1-1/16". I've put brass sleeves in several hundred of them. Depending on whether you calculate up or down, the difference between 1" and 1-1/16" is about 11% or 13%. Depending on the pedal ratio, that would probably be about 1" to 1-1/2"of pedal travel--more travel for the smaller cylinder, as you say. I'd have to check my books before I said for sure, but off the top of my head the first 1-1/8" Ford cylinder was used in mid-'50s cars with power brakes. Joe
07-04-2011, 05:34 PM | #31 | |
You must have the later brakes, called in MOTOR'S "Lockheed [3]", with a single eccentric anchor at the bottom (or for you, the top since your backing plates are upside down). Here are scans of the adjustment procedure. The main difference is that the single eccentric anchor is adjusted for the front shoe only (again, as shown in Vince's photo the rear shoe). If the heel of the forward shoe is not adjusted correctly, you will lose considerable pedal travel as the wheel cylinder tries to push the shoe into contact with the drum--even if the toes of the shoes, controlled by the cams at the sides of the backing plate, seem to be properly adjusted. Joe LockheedAdjust3.jpg LockheedAdjust4.jpg
1929 Tudor since 1962 Feather River A's Last edited by JoeWay; 07-04-2011 at 05:40 PM. |
07-04-2011, 06:51 PM | #32 |
Just went through the same problem as you. I switched the cylinders so that bleader is on top. cylinder still on bottom of backing plate. This requires grindint the hole so that the bolts line up with the cilinder. I ground the big hole so that the bolt holes lined up this left a quarter moon shaped hole on the bottom which has not been a problem. I used a master cylinder from a 1967 mustang. We removed the rear line and pluged the master. We then were able tobleed the front brakes. Keep bleeding even when you think you got all the air.WE then hooked up the rear and bleed them. When you bleed rear be very gental when you pump so as not to upsead the front. We then adjusted the brakes. After about 100 miles we bled the front and back with disconecting anything but be very gentle when you pump so as not pumpair from frotn to back and vice versa.We know have very good brakes.Much better than expeced. John
07-04-2011, 07:04 PM | #33 |
Steinar: On post #31 you mention that M/Cyl is on firewall. If so what kind? Are you utilizing "hanging" pedals? As I read your post I assumed (I know....) that you had a 39-48 M/Cyl mounted under the floor. Not that this has any real thing to do with your bleeding problem, but I think you could get away w/out a "rubber" connection to the frame at this point. When I did my 32 with chev dual resivoir m/cyl (hyd brakes and clutch) I only used a pre-formed tube for the clutch connection, not the brakes.
Paul in CT |
07-04-2011, 08:28 PM | #34 | |
I think I am going to back out of this discussion since I don't have access to the data I need. Even if I looked up the early Ford (I am sure you are right) I still don't know what the other master cylinder is from. Charlie Stephens |
07-04-2011, 09:19 PM | #35 | |
If you're wondering about my bona fides, check the URL in my signature. Joe P. S. I shouldn't have said I've sleeved "several hundred" of the early Ford cylinders. On reflection, I think probably about 100 is a better number.
07-04-2011, 10:40 PM | #36 | |
Charlie Stephens |
07-05-2011, 11:13 AM | #37 | ||
I don't recall whether Steinar said his system was functioning acceptably in terms of pedal travel and effort required when he started rebuilding it. If it was, then the mechanical ratio must have been OK. Joe
08-05-2012, 02:31 PM | #38 |
not to steal the thread , but im having major problems bleeding mine . 1931 ford coupe , 1942 hyd brakes . used a vaccum bleeder , no luck . used the helper old style bleeding ... seems there is no air , but the pedal still goes to the floor . it is firmer than when i started & when pumped it does activate the brakes , but no good pedal . any ideas appreciated . thanks .. steve
V4f |
08-05-2012, 02:45 PM | #39 |
Years ago Dave Wilton (mt products) master brake guy, posted on upside down backing plates as i recall it was not recommended?
08-05-2012, 04:44 PM | #40 |
One thing you said that stands out at me,the second pump of the pedal is rock hard.Air=sponge.Liquid=rock.Air compresses,liquid does not.If the pedal gets hard,not spongy,I would call it a travel problem too.
08-05-2012, 04:57 PM | #41 |
This thread is more than a year old. I suspect Steinar solved his problems long ago.
Joe
08-05-2012, 06:56 PM | #42 |
A long way back in trade school we taught to adjust the shoes to drum first on all wheels to ensure minimum travel of the brake shoes. Perfect setting was not required at that time. With a good helper....it is now time for bleeding the brakes.
I use a glass jar 1/2 filled with the appropriate clean brake fluid, and a clear piece of plastic tubing. Start your bleeding proceedure at the closest wheel to the master cylinder. With the plastic tubing attached to the wheel cylinder bleeder and the other end submersed into the fluid in the jar, loosen of the bleed screw while instructing your helper to pump the pedal. When you have received a good stream of fluid into the jar with no air bubbles, have your helper depress the pedal down to about half way of travel....stop....and hold. while you tighten the bleed screw without lifting the tubing from the fluid. Sometimes you may have to empty the bleed jar a couple of times, but remember to close the bleed screw each time you remove the bleed jar from the tubing end. Proceed to the wheel that is next closest to the master cylinder and repeat the same proceedure. Follow the same proceedure for the third closest wheel and finally the last. You should have a firm pedal if everything is tight. Make final adjustment of the brakes. |
08-05-2012, 08:04 PM | #43 |
I use a pump oil can and a piece of rubber hose the reverse bleed brakes. Put the hose on the bleeder valve. Open the valve and pump fresh fluid in till there are no bubbles in the master cylinder. Of course two sets of eyes are needed.
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? |
08-05-2012, 08:22 PM | #44 |
glenn c.
wow that is totally opposite from most ideas . but i sure can see how it would work ! learn something every day . thanks
V4f |
08-06-2012, 12:31 AM | #45 |
I was taught to bleed brakes in the following order-- RR,LR,RF & LF.The 39-41 brakes have adjustable anchor pins-the 42-48 are not.Adjust the brakes as best you can before bleeding them.You can switch the cyls side to side to put the larger bore to the front & get bleeder on top or you can put the cyls on top with minor mod to backing plate & filing or grinding a groove in spring perch to allow the brake line to fit WC.You need a flex line from MC to V shaped steel lines on front of DS hsg as there is movement every time R E moves up & down.
08-06-2012, 07:04 AM | #46 |
08-06-2012, 07:32 AM | #47 |
i have a residual valve in line . my fronts are on top , my rears are 20* OC . thanks
V4f |
08-06-2012, 06:58 PM | #48 |
Just went through the same issue using inverted rear backing plates on my A.
The problem turned out to be "insufficient master cylinder piston travel". The advertised pedal mechanism I purchased wasn't even close to having the 1 1/2" stroke required for my master cylinder. As soon as I changed the lever length and modified the pushrod, instant pressure. I bled the rear cylinders by cracking the line at the cylinder. Ken |
08-06-2012, 08:00 PM | #49 |
ken , i just spent all day rechecking every thing .
i found that i did not have enough travel also !! what a deal this has been . thank you for confirming my thoughts . gonna re-design my set up tommorow . i did find some little things i missed the first time , so it turned out to be well spent time . *** thank you all for your great help . ill let you know how it comes out ... steve
V4f |
08-06-2012, 10:53 PM | #50 |
If you had rebuilt mechanicals with Teds Floaters you would have better brakes with less pedal pressure than the old Wagner hydraulics.
08-07-2012, 01:50 AM | #51 | |
IF IT CAN NOT BE FIXED WITH BLASTING WIRE, JB WELD OR DUCT TAPE ---IT CAN NOT BE FIXED Do not get me started on the stupidity of ethanol. I think one of the monitors is from Iowa and he will delete the thread. |
08-07-2012, 08:17 AM | #52 |
i am a firm believer in teds kits . have used them for like 10 yrs . i put a s-10 5 speed in my coupe & it is in the way of the rod from the pedal . revamped but lost leverage . thus the hyd . ............... thanks .. steve got teds kit 4 sale !
V4f |
08-07-2012, 02:15 PM | #53 |
well im very close now . drove it today . a little fine tuning & ill be done with that !
thanks to all that helped me !!!!!!!!!!!!!!! the last problem was leverage from the pedal to the mc ................. steve
V4f |
08-07-2012, 03:17 PM | #54 |
Swap the cylinders and modify the backing plates, then it's a done deal....
