Old 10-23-2021, 10:46 AM   #1
Ramblin Reck
Ramblin Reck's Avatar
Default 1939 Ford Vert Cowl Vent will not budge
Can't open the vent to let in fresh air. Don't want to force it and break something. Click on pic to expand. Need advice Thanks!
Ramblin Reck is offline   Reply With Quote
Old 10-23-2021, 10:52 AM   #2
marko39
Default Re: 1939 Ford Vert Cowl Vent will not budge
Most likely the lid seal is stuck. I would disconnect lid from mechanism to verify which is the problem and prevent damage.
marko39 is offline   Reply With Quote
Old 10-23-2021, 11:02 AM   #3
19Fordy
19Fordy's Avatar
Looks like someone did some home made rehab on the vent mechanism. Do as marko39 says and then spray all the mechanical parts of the vent with WD-40 or PB Blaster to free things up. Previous owner may have tightened all the movable opening parts tight so vent couldn't be opened. It looks like someone tried to seal the vent closed. If the 39 vent mechanism is the same as the 40, I can send post photos of how it looks originally from the factory..
Old 10-24-2021, 08:03 AM   #4
Ramblin Reck
Thanks
Old 10-24-2021, 09:10 AM   #5
19Fordy
19Fordy's Avatar
Ramblin Reck: Here's a thread that may help.
https://www.fordbarn.com/forum/showthread.php?t=40854
Old 10-24-2021, 12:11 PM   #6
alanwoodieman
picture of cowl vent from outside?
alanwoodieman is offline   Reply With Quote
Old 10-25-2021, 09:48 AM   #7
Ramblin Reck
Old 10-25-2021, 10:13 AM   #8
Ramblin Reck
You betcha it helps! Thanks!
Old 10-25-2021, 09:37 PM   #9
Veeder
I had a similar problem years ago everything had to come apart then lastly pushed open the vent. Bottom line it all had to come apart
Veeder is offline   Reply With Quote
Old 10-25-2021, 10:48 PM   #10
petehoovie
petehoovie's Avatar
The only thing nice about being imperfect is the joy it brings to others....
"Silver rings, your butt! Them's washers!"
"We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969
https://www.youtube.com/watch?v=7NReUd2_0u0
Old 10-26-2021, 07:02 AM   #11
Terry,OH
Terry,OH's Avatar
Appears the vertical portion of the door is bent and interfering with the screen. It should have been bolted to the hinge in four places and is not. I also suggest you take the inside portion apart to see if you can get it straightened out. The screen already has a hole in it so don't be afraid of damaging it since it is reproduced and common to the 40
Old 10-31-2021, 04:21 PM   #12
billbrown
mine was a bear too. lots of PB Blaster
billbrown is offline   Reply With Quote
Old 11-01-2021, 01:56 PM   #13
Bill Wyckoff
Had this problem on my 37. Soaked it from top side with WD40. A day later it broke loose.
Bill Wyckoff is offline   Reply With Quote
