Old 10-18-2021, 08:18 PM   #1
novaskilling
Default Banjo oil recommendation
I have a 40 ford banjo rear that i just drained. Im wondering what oil is best to use today?
novaskilling is offline   Reply With Quote
Old 10-18-2021, 08:30 PM   #2
Holeshot
Default Re: Banjo oil recommendation
Sta-Lube SAE 140
"Sometimes he would accuse chestnuts of being lazy, the sort of general malaise that only the genius possess and the insane lament."
Holeshot is offline   Reply With Quote
Old 10-18-2021, 08:34 PM   #3
Bursonaw
Bursonaw's Avatar
The OEM recommends 140W for warmer climates and 90W for colder climates. Modern gear oil it’s multi weight. I’ve been using 85w-140W for many years with no issues. I also use 75w-90W in my transmission and it seams to shift better on cold days.
Sent from my iPad using Tapatalk
Bursonaw is offline   Reply With Quote
Old 10-18-2021, 09:20 PM   #4
19Fordy
19Fordy's Avatar
I use Stalube GL-140 in my 40 differential and transmission. It's on the shelf at O'Reilly's for $19.99 which is a great price considering other stores get $46. Buy 2 gallons as I am sure the price will be going up with inflation the way it is today. I used to use 600W gear oil from BOB DRAKE but changed after reading this:
https://www.fordbarn.com/forum/showthread.php?t=73472
https://bobdrake.com/products/univer...UaArb9EALw_wcB.
https://www.oreillyauto.com/shop/b/c...ear+oil+-+140w
Here's some good info.
https://www.jalopyjournal.com/forum/...earend.133327/
Some folks might use GL-5 in the banjo but it has additives that corrode brass. That's why I use GL-140 in both diff and transmission. Easy to remember. Read this: https://fordbarn.com/forum/showthrea...9484&showall=1
Make a little tag and JB Weld it on your rear end and transmission as a reminder. Also make a tag for the gear ratio. For instance 9/34 for 3:78. Very unobtrusive and helpful. Make a little tag for your steering box also and secure it using a wire tie. Hope this info. helps.
Old 10-18-2021, 09:30 PM   #5
alanwoodieman
GL 1 to 4 only! doping can be multi weight but no GL5
alanwoodieman is offline   Reply With Quote
Old 10-19-2021, 12:58 AM   #6
deuce_roadster
deuce_roadster's Avatar
I am curious as to what brass is in a standard banjo rear end that would be affected by GL-5? Question to both alanwoodieman and 19Fordy? I have Columbias and know there is only 1 thin washer like part that is brass in there.
I know that is why you don't put GL-5 in a gearbox with brass synchro rings.
I have been using Redline products (GL-4 MT for trans, GL-5 for differentials) with no problems.
Old 10-19-2021, 06:00 AM   #7
PeteVS
PeteVS's Avatar
Recommended lube for a rolling sector (F1) steering box?
Don't never get rid of nuthin!
PeteVS is offline   Reply With Quote
Old 10-19-2021, 06:13 AM   #8
1952henry
1952henry's Avatar
Cornhead grease #0, available at any color implement dealer, if corn is grown in the area (psst it doesn't have to say John Deere) or cotton picker spindle grease #00., cheap at tractor supply.
I dig coal, which provides motivation for EVs.
1952henry is offline   Reply With Quote
Old 10-19-2021, 07:13 AM   #9
19Fordy
19Fordy's Avatar
deuce roadster; I don't think there are any brass parts inside a normal 1940 banjo.
I don't know about Columbia rear components so can't comment on that. I just figure its safe to use GL-4 in both.
Old 10-19-2021, 07:21 AM   #10
Lawson Cox
Lawson Cox's Avatar
I use GL4 in my guitar. I don't have a banjo. Not enough strings.
Old 10-19-2021, 09:45 AM   #11
Drbrown
Drbrown's Avatar
I have moderately cold winters but like others here, I use GL-140 year round. I also use same in my BW overdrive unit. In transmission I use the lower viscosity 90 to improve shifting. I buy my stuff at Amazon and get free shipping and good prices.
Steering Box Lubricant: Based on older posts on this forum, have good results (less leaking) with "Penrite" Steering Box Lube 500ML (was 29.55) from Restoration Supply, Escondido CA (800) 306-7008; RestorationStuff.com ............. hope they are still in business.
Drbrown is offline   Reply With Quote
Old 10-19-2021, 10:45 AM   #12
deuce_roadster
True 19Fordy, will work in both. I believe the GL-5 has more extreme pressure additives then the GL-4. Probably the additive that eats brass. Thanks for the clarification.
Old 10-19-2021, 11:10 AM   #13
19Fordy
19Fordy's Avatar
You are correct. GL-5 has the additives that dissolve brass. GL-4 does not.
Here's a very informative post about GL-4 and GL-5 and brass initiated by Lawson in 2017.
I think it answers lots of questions.
Old 10-19-2021, 03:40 PM   #14
glennpm
glennpm's Avatar
Yes the Columbia has brass parts and the reason I use GL-4 and like 19Fordy, bought it at a good price from O'Reilley's.
Old 10-20-2021, 12:26 AM   #15
deuce_roadster
Glennpm, I only saw 1 brass part in each of my Columbias. Was a thin brass disk with 3 oblong slots. Were there others? I have 1940 units. I use the GL-5 in my 3 non Columbia Fords- 33 phaeton, 32 roadster and 32 5w.
Old 10-20-2021, 08:40 AM   #16
glennpm
glennpm's Avatar
Yes Deuce there are five parts total, the one you can see in the picture above and four that go over the spider ends.
Old 10-20-2021, 09:21 PM   #17
deuce_roadster
Glenn, Thanks, I had forgotten about those behind the spiders. The one I did remember however kept me from using the GL-5 in them. I only use it in my standard banjos.
Old 10-20-2021, 09:38 PM   #18
alanwoodieman
mostly GL4 or below is because most people only need to keep up with one bottle of trans/rear lube--if you made a mistake and put GL5 in your columbia what would this small mistake cost you?
Old 10-21-2021, 07:10 AM   #19
glennpm
glennpm's Avatar
You're welcome Deuce and yes it could be a very costly mistake Alan!
Glenn
