Old 08-20-2016, 07:52 PM   #1
Dennis Pereira
Dennis Pereira's Avatar
Default Front Brakes
I'm putting the brakes together on the work bench to save my knees and back . The short springs were a lot stronger than I expected and the brake adjusting wedge dust cover was a lot larger than the opening . But that's what a grinder a file and a little sanding took care of . If anything looks wrong let me know better now than on the way down the mountain . New brake lining - rollers - pins - adjusting wedges -roller tracks - actuators - springs . should work a lot better than the mud and grease filled assembly's that came off .
Dennis in Kelsey ca
Dennis Pereira is offline   Reply With Quote
Old 08-20-2016, 09:24 PM   #2
MAG
MAG's Avatar
Default Re: Front Brakes
Assembly looks correct. You did arc the shoes to the drum first?
If you have a extra spindle handy, bolt the backing plate to it and bench test/adjust the centering of the shoes before installing on the car. Re-check the centering after final installation on the car in case there is any variation on the spindle to backing plate fit.
I noticed the harder I work the luckier I get!
MAG is offline   Reply With Quote
Old 08-21-2016, 09:19 AM   #3
redmodelt
redmodelt's Avatar
Did you put a little grease on the adjuster and rollers before you installed? Looks good.
Old 08-21-2016, 09:41 AM   #4
160B
160B's Avatar
When I did the brakes on my 1931 68B I found that the lower roller on the brake shoe did not rest against the edge of the oval plate on the bolt that holds the operating wedge in place. When I disassembled the brakes I found that the reproduction oval plate was not as thick as the original and the roller on the brake shoe was not resting in the correct position. I removed the reproduction floaters and put the original wedge support in. see photos below
reproduction
original
reproduction next to original
1931 160B & 1931 68B
If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time?
160B is offline   Reply With Quote
Old 08-21-2016, 01:54 PM   #5
ian Simpson
Do not forget to make that high-melting point grease.
ian Simpson is offline   Reply With Quote
Old 08-21-2016, 02:08 PM   #6
Dave in MD
You also may want to take some more of the lining material off of the end of each shoe. I like to go back to almost the end two rivets.
Dave
Dave in MD is offline   Reply With Quote
