Old 08-20-2016, 09:01 PM   #21
tbirdtbird
Default Re: Locking Pins
" I think a box wrench is the same as a ring spanner"
That is the conclusion I came to.
We will all just have to accept there are differences in usage among various countries. Bonnet, hood; crown wheel, ring gear; cotter pin, taper pin; take a slash, take a whiz; and so on. It just is.
I had a devil of a time reading an English service manual on a Rolls when I encountered the term, 'distance piece'. WTH is that I said. I went onto a worldwide refrigeration board that I am on frequented by Limeys and they confirmed that it simply meant 'spacer'
gee why didn't you say so LOL
'31 180A
tbirdtbird is offline   Reply With Quote
Old 08-20-2016, 09:36 PM   #22
Synchro909
Synchro909's Avatar
If a ring spanner is known as a box wrench, what is a socket spanner called. Seems to me that Box wrench would be a closer name for a socket. Socket spanners:
[url]www.google.com.au/search?q=image+of+socket+spanner&espv=2&biw=1242&b ih=606&tbm=isch&tbo=u&source=univ&sa=X&ved=0ahUKEw j124vHvNHOAhWEj5QKHYXODEgQsAQIGg[/url
Imagine my confusion when I read about a ZERK. WTF is that, I thought. Good old Mr Google came to the rescue again.
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 08-20-2016, 09:53 PM   #23
Tom Wesenberg
Tom Wesenberg's Avatar
We simply call them sockets, and they are mostly 6 point sockets and 12 points sockets, but sometimes you can find 4 point and 8 point sockets. Points = number of flats.
Old 08-20-2016, 10:23 PM   #24
ian Simpson
Originally Posted by Synchro909 View Post
I've just gone through this when I found the king pin was loose in the eye of the axle. On Monday, I'm going t a friend's workshop and we will close the eye again. The COTTER PIN should look like your pictures show. All of my As are like that. I find a good way to make sure they are tight is to hold pressure on the nut with a ring spanner while I hit the head of the cotter pin with a hammer. With each blow, the spanner will turn a little more. Stop before you stretch the cotter pin.
Luv it when a bloke uses real English.
The cotter pins on my Tudor are about 1/8 inch proud.
Another name for a big hammer - Glasgow screwdriver.
ian Simpson is offline   Reply With Quote
Old 08-21-2016, 03:20 AM   #25
Synchro909
Synchro909's Avatar
Another name for a hammer - an adjuster. The bigger the hammer,the finer the adjuster.
