06-22-2010, 07:16 AM | #41 |
Re: My New 1930 Sedan
Another welcome to the hobby! Model A's are FUN, reliable, and easy to get parts for. They are a rugged car and reasonably easy to work on. In addition, there's a wealth of information to be learned by doing and by joining a local club. I'm a Tudor owner too (1930) - about one of every four Model A's ever built was a Tudor. A great family car; it's the one that most people remember. Your car looks very solid. You can remove the heater top (if it's an Autolite) and a Tillotson Carburetor will serve you well even though it is not original. From your inside pictures, it looks like you have an aftermarket oil (or temperature) gauge under the instrument cluster. That's a nice accessory. Most of all, drive it and anjoy it. Go get ice cream in it. Take the kids and their friends for a ride in it. Talk to people about it. You'll get lots of lookers and questions. Model A's were perfect only when they came off the assembly line. (Don't get me wrong - I like to look at Blue Ribbon Cars.) See you on the road!
Any car can drip oil, but for a real puddle, it takes a Model A. |
06-22-2010, 11:51 AM | #42 |
The wheels look like they are from a 1935 Ford. I bet the tire size is 600-16. A lot of people prefer these wheels so don't rush to change them unless you need new tires. When you need to buy tires decide if you want to keep the 16 inch wheels or go back to the original 19's.
Charlie Stephens |
06-22-2010, 12:25 PM | #43 |
Nice ride. I only have one question? In the First picture of the engine I noticed that it looks like the steering shaft is exposed. Has the steering column been cut? Or am I just seeing things. Richard/Ca
06-22-2010, 03:51 PM | #44 |
There is a good parts guy in AZ at Arizona Model A, LLC located in Chandler at 15838 S Gilbert RD. Sam does do work on A's and T's if required. If you have a problem and need help I am located in Pine, AZ and have a daughter in AJ. Welcome to owning a Model A. They are quite a blast.
06-26-2010, 12:45 PM | #45 | |||
Thanks, Tim |
