08-20-2016, 07:52 PM | #1 |
Front Brakes
I'm putting the brakes together on the work bench to save my knees and back . The short springs were a lot stronger than I expected and the brake adjusting wedge dust cover was a lot larger than the opening . But that's what a grinder a file and a little sanding took care of . If anything looks wrong let me know better now than on the way down the mountain . New brake lining - rollers - pins - adjusting wedges -roller tracks - actuators - springs . should work a lot better than the mud and grease filled assembly's that came off .
Dennis in Kelsey ca |
08-20-2016, 09:24 PM | #2 |
Re: Front Brakes
Assembly looks correct. You did arc the shoes to the drum first?
If you have a extra spindle handy, bolt the backing plate to it and bench test/adjust the centering of the shoes before installing on the car. Re-check the centering after final installation on the car in case there is any variation on the spindle to backing plate fit.
I noticed the harder I work the luckier I get! |
08-21-2016, 09:19 AM | #3 |
Re: Front Brakes
Did you put a little grease on the adjuster and rollers before you installed? Looks good.
08-21-2016, 09:41 AM | #4 |
Re: Front Brakes
When I did the brakes on my 1931 68B I found that the lower roller on the brake shoe did not rest against the edge of the oval plate on the bolt that holds the operating wedge in place. When I disassembled the brakes I found that the reproduction oval plate was not as thick as the original and the roller on the brake shoe was not resting in the correct position. I removed the reproduction floaters and put the original wedge support in. see photos below
reproduction original reproduction next to original
1931 160B & 1931 68B If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time? |
08-21-2016, 01:54 PM | #5 |
Re: Front Brakes
08-21-2016, 02:08 PM | #6 |
Re: Front Brakes
Dave |
