Old 06-03-2021, 11:41 AM   #1
46woodie
Default Identiy type of machine screw 46 woodie door handle
Ok, on the front doors of the woodies 46-48 there is a small hole on the INSIIDE of door that is inline with the outside door handle shaft. A small machine screw 10-32 with a long slotted head inserts into hole and screws ihto back of door handle shaft. What are these fasteners called so I can find one and buy it? Person that replated my parts lost one,I need another. thanks!
46woodie is offline   Reply With Quote
Old 06-03-2021, 11:48 AM   #2
rockfla
rockfla's Avatar
Default Re: Identiy type of machine screw 46 woodie door handle
Not sure but would most likely guess this is the type screw and IF so it is an Oval Head Slotted Machine Screw
Old 06-03-2021, 11:50 AM   #3
46woodie
Nope,thanks
Old 06-03-2021, 11:54 AM   #4
rockfla
rockfla's Avatar
Following
Old 06-03-2021, 12:01 PM   #5
51 MERC-CT
51 MERC-CT's Avatar
10/32 round head slotted machine screw along with a star lock washer. (hardware store items)
Old 06-03-2021, 12:05 PM   #6
rockfla
rockfla's Avatar
If it is a Round head like this, let me have the length and I "most" likely have one in stock in Stainless Steel, I will polish the head for you and send you "One".
Old 06-03-2021, 12:05 PM   #7
46woodie
Tried taking pics and sending but no luck. The head on this type fastener is nearly as long as threaded portion. I think early 30's fords may have used this style of bolt on door handles also
Old 06-03-2021, 12:07 PM   #8
46woodie
No and no. Those are both very common fastners. No lock washer
Old 06-03-2021, 12:08 PM   #9
Tony, NY
Post a pic of the one you still have. It would help a lot.
We both posted at once.
Tony, NY is offline   Reply With Quote
Old 06-03-2021, 12:09 PM   #10
rockfla
rockfla's Avatar
these are the other two commercially available types of head I can think of that it could possibly be IF not a Round, Flat or Oval head. IF its not one of these then its a "special" make screw!!!!
Old 06-03-2021, 12:20 PM   #11
46woodie
46 WOODIE. nothing like other models. BUT, I have seen these bolts before. Similar to fillister but head even longer. Yes, may have been special made forvthis and a few other models
Old 06-03-2021, 12:21 PM   #12
51 MERC-CT
51 MERC-CT's Avatar
If not round head then 'panhead'
Old 06-03-2021, 12:24 PM   #13
rockfla
rockfla's Avatar
Cheese head is the only other style and between the cheese head and Fillister head its splitting hairs!!!! IF its not a cheese or fillister your SOL. unless you find someone here on the barn that has that particular screw
Old 06-03-2021, 12:26 PM   #14
DavidG
DavidG's Avatar
Various earlier inside door handles were secured with nickel-plated #10-32 pan head screws.
Old 06-03-2021, 01:35 PM   #15
Zeke3
Zeke3's Avatar
What you are describing sounds like a shoulder screw. You might try McMaster-Carr.com to see if you can find a size that works for you. The only one I found without a head is only available in metric threads.
Thread size=10-32, shoulder diameter=?, shoulder length=?
https://www.mcmaster.com/screws/shoulder-screws/
P.S. it looks like for a 10-32 screw the shoulder diameter will be 1/4" from McMaster-Carr.
Last edited by Zeke3; 06-03-2021 at 01:43 PM. Reason: added fastener characteristics & PS
Zeke3 is offline   Reply With Quote
Old 06-03-2021, 02:00 PM   #16
46woodie
Alright,attached a pic,may help
Old 06-03-2021, 02:08 PM   #17
deuce lover
deuce lover's Avatar
I have one. The head is nickel plated and7/16 dia and length is 5/8 and its brass .
If that works for you click on my user ID and send me your address.I posted this before I saw his picture.Oh well I tried.
deuce lover is online now   Reply With Quote
Old 06-03-2021, 02:28 PM   #18
rockfla
rockfla's Avatar
What you have pictured in the first post you will not find anywhere as a commercially available item. Support your local machinist!!!
Old 06-03-2021, 02:36 PM   #19
DavidG
DavidG's Avatar
Sheldon,
That's not an easily-found fastener these days as the head diameter is that normally found on a #12 screw of the same type. They were used on early '32s to attach the dash to the cowl before the hole size was enlarged from #10 to #12.
Old 06-03-2021, 02:44 PM   #20
46woodie
Thanks Sheldon, knew I had seen them before.
Dont have to have new. Someone from project will come up with one. Thanks deuce lover,looks identical to mine
