Old 03-20-2021, 01:03 PM   #1
3twinridges
3twinridges's Avatar
Default 8RT carb rebuild
I am rebuilding an 8RT carb that I picked up on eBay. It looked pretty good and still had the tag so I figured it wasn’t too worn out. It has a lot of play in the throttle shaft, a 0.281 door pin slides in pretty easily so I have a new base on the way. I have been practicing the chromate dip on a junk air horn and have it down pretty good. It was a little darker than I wanted so I will adjust the time slightly on the real one.
The fuel inlet nut gets a little tight at the bottom. Before I run a thread repair in there I wanted to confirm the thread size. Are all 8RT air horns 1/2-20 threads?
JB
File Type: jpg 0E244183-0482-4767-909D-AF2BC417B9BF.jpg (76.7 KB, 54 views)
3twinridges is offline   Reply With Quote
Old 03-20-2021, 01:24 PM   #2
Scotty's 52 F3
Scotty's 52 F3's Avatar
Default Re: 8RT carb rebuild
CharlieNY would know.
Scotty's 52 F3 is offline   Reply With Quote
Old 03-20-2021, 04:00 PM   #3
mfirth
x 2 on Charlie. The man.
mfirth is offline   Reply With Quote
Old 03-20-2021, 04:53 PM   #4
Mart
Mart's Avatar
Threads are 1/2-20.
Old 03-20-2021, 05:04 PM   #5
3twinridges
Thank you Mart! I hit it with a thread repair and it cleaned up, thank you for confirming!
JB
Old 03-20-2021, 07:24 PM   #6
scicala
scicala's Avatar
Yes, I 2nd that. 1/2-20
Sal
Old 03-25-2021, 12:44 PM   #7
3twinridges
I trued up the carb base and bottom base. Those meet nicely and I see no light. On the air horn to carb base, I had to true it also. Started with 220 on a sanding block and worked up to 1000 grit. Both edges fit pretty well with the screws torqued to 7 inch/lbs. In some places I can get a 0.0035 feeler in but a 0.004 will not go. The gasket thickness is 0.030 so in my mind I should be good to go, but wanted to confirm with the experts.
JB
