Old 09-21-2020, 09:28 AM   #1
James 47
James 47's Avatar
Default Engine stops when it is hot
Hi all! I have a 1947 Ford Super Deluxe Coupe with the 239 cu in Flathead engine. A while ago, I have a problem, and that is that when the engine gets hot, it shuts down. In cold it starts very well, the car runs fine, but when the engine is hot, it shuts down. And I can only turn it on again, when I let it cool. Someone went through this and can you guide me? Thank you very much!
James 47 is offline   Reply With Quote
Old 09-21-2020, 09:35 AM   #2
WABOOM
WABOOM's Avatar
Default Re: Engine stops when it is hot
Ignition coil.
WABOOM is offline   Reply With Quote
Old 09-21-2020, 09:46 AM   #3
WABOOM
WABOOM's Avatar
I had the exact same problem. I chased what I thought was vapor lock for a month but it turned out to be bad coil.
Old 09-21-2020, 09:51 AM   #4
James 47
James 47's Avatar
I thought the same, about fuel. But yesterday I noticed the coil very very hot and I started to think that it could be that. Thanks for your experience.
Old 09-21-2020, 02:15 PM   #5
Don
Don's Avatar
I think people should check the current draw of ignition circuit more often when a coil is suspect or getting hot, or the resistance in circuit is in question,I think about 3 amps give or take a little is @ good number...
DON P
Don is offline   Reply With Quote
Old 09-21-2020, 03:46 PM   #6
Sal
Have your coil rebuilt by Skip Haney in Punta Gorda Florida.
Sal is offline   Reply With Quote
Old 09-21-2020, 04:23 PM   #7
wga
wga's Avatar
James - if converted to 12 volt, the Bosch blue coil is the way to go - internally resisted.
Henry Ford designed the flathead without the aid of a computer.
wga is offline   Reply With Quote
Old 09-21-2020, 05:33 PM   #8
50fordcoupeman
50fordcoupeman's Avatar
Agree on the coil. I had two that did this.
50fordcoupeman is offline   Reply With Quote
Old 09-21-2020, 07:00 PM   #9
aussie merc
aussie merc's Avatar
classic coil failure
aussie merc is offline   Reply With Quote
Old 09-22-2020, 07:59 AM   #10
James 47
James 47's Avatar
Finally I changed the coil yesterday and it seems like the trouble desapear.
However the new coil keeps getting hot. Anyone know if this is normal? Or if as Don says, I should check the dynamo or the circuits? Thanks to everyone for your replies
Old 09-22-2020, 08:13 AM   #11
51 MERC-CT
51 MERC-CT's Avatar
Check the ignition resistor for proper function.
Old 09-22-2020, 06:17 PM   #12
JSeery
JSeery's Avatar
You can check the voltage at the coil. What voltage is the vehicle and what coil are you using?
Old 09-23-2020, 08:54 AM   #13
Veeder
Make sure your gas cap is venting
Veeder is offline   Reply With Quote
