09-03-2020, 08:03 PM | #1 |
Champion H-9 plugs
Guys I picked up a set of five ribbed H-9 plugs for our 52 F1 build. They have made in Canada rather than US but figure that is closer to original than new Autolite 216’s if we ever show it.
The plugs have a very fine rust and corrosion in spots. Any ideas on rust removal and restoration to keep from rusting? JB |
09-04-2020, 12:56 AM | #2 |
Re: Champion H-9 plugs
Removing the rust may also remove the bluing. Converting the rust to iron oxide would not remove any bluing, and the resulting color of iron oxide would be a close match to the bluing. A product that does that is Rustmort, available at paint stores. I would brush it on liberally, let it dry overnight, then buff it off. I believe you'll see results better than you could imagine.
A word of caution: I would try it on a small area of one plug first, just to experiment. I know for a fact that a rusty floorboard can be miraculously transformed with this stuff. P.S.~ You do know that you can get H10C plugs (super cheap) at hardware stores and blue them yourself?
Alan |
09-04-2020, 02:15 AM | #3 |
Go to a gun store and get this >
Birchwood Casey Liquid Gun Blue Kit Amazon sells it as well > https://www.amazon.com/Birchwood-Cas...9203942&sr=8-1 Birchwood Casey Liquid Gun Blue Kit is the best gun bluing kit that makes everything you need to blue or re-blue several rifle barrels. It is made using the highest quality materials and components. This blue is excellent for cleaning smoke residue from stainless steel surfaces. They are easy to use while fast-acting liquid gives a non-streaky, uniform blue-black finish to steel. The packaging includes bluing applicators, a sponge and a service cloth Barricade Rust Protection Gun Wipes and also has complete instruction guide. For the beginners who want to learn more about the bluing kit than Birchwood Casey Liquid gun bluing kit is coming with a complete package which is the best one for you.
The only thing nice about being imperfect is the joy it brings to others.... "Silver rings, your butt! Them's washers!" "We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969 https://www.youtube.com/watch?v=7NReUd2_0u0 Last edited by petehoovie; 09-04-2020 at 02:21 AM. |
09-04-2020, 08:31 AM | #4 | |
H9 (USA) plugs are often offered on eBay. They are quite reasonable as well - especially the five rib variety.
09-04-2020, 10:46 AM | #5 |
Good intel guys, thank you. I am going to restore these as suggested but it seems like a waste from a looks/time perspective. I am pretty sure the plug boot is going to cover the top of the plug where the Champion H-9 logo is, and the bottom of the plug is all you will see, which is almost identical to the 216’s.
JB |
09-04-2020, 01:27 PM | #6 |
They are available and open for offers. Thanks Tom. |
09-04-2020, 01:35 PM | #7 | |
These were the ones I'd mentioned in an earlier post that are frequently on eBay... they usually bring about $10 each, sometimes a bit more. If these were two rib H10's I'd be al over them Those bring $55+ each.
"I can explain it for you. However, I can't understand it for you". Last edited by Kube; 09-04-2020 at 03:29 PM. |
09-04-2020, 01:52 PM | #8 |
Mike, I was not sure of the cutoff year for two rib Champions for trucks or cars.
What do you say? I just put them out there to be seen. They look like they were just made. I think you should do a Forty Truck! |
09-04-2020, 02:01 PM | #9 | |
I'm not 100% certain when the two rib ended and the five rib started. I think 1942... I think.
09-04-2020, 02:34 PM | #10 |
09-04-2020, 06:43 PM | #11 |
Tom, email me about the two rib H-9;s. [email protected] , thanks...-RG
