Old 11-25-2021, 08:05 AM   #21
aermotor
Default Re: Air Filter
Originally Posted by chrs1961815 View Post
Air maze was an original aftermarket accessory that everybody seems to remember simply because the design was duplicated many times over the years. There was probably some different designs in the era, might be in the unauthorized accessories book.
What is the unauthorized accessories book? What does it say and the what was the reason? Ford sure produced a lot of cars without them.
John
aermotor is offline   Reply With Quote
Old 11-25-2021, 10:17 AM   #22
old ugly
old ugly's Avatar
John
the air maze was an authorized by ford accessory but there were lots of other brands of air cleaners. it was well known at that time that it was not a good thing to have dirt going through your engine.
this is the unautherized book they were taking about and a few different types of air cleaners available
run an air cleaner the car will run just fine with it.
old ugly
my old father-in-law told me. "listen close when people tell you how to do stuff they may know something. then do it the way you want."
old ugly is offline   Reply With Quote
Old 11-25-2021, 11:45 AM   #23
katy
katy's Avatar
I bought a high-boy air cleaner and put it on. A few days later I opened the hood to check the oil and noticed the high-boy was AWOL.
What the heck, I hadn't driven the A very much, but there it was, gone.
If there's a next time I'll put a safety chain or some other sort of retainer on so if'n it comes off it won't get lost.
Old 11-25-2021, 11:53 AM   #24
Ruth
Do you have engine pans installed? My air filter fell off once but was "saved" by the engine pan.
Ruth
Old 11-25-2021, 12:35 PM   #25
katy
katy's Avatar
No engine pans, I'll have to look into at either getting a set or make some.
Old 11-25-2021, 07:37 PM   #26
burner31
burner31's Avatar
Highly recommend Katy
Keith
Shawnee OK
'31 SW 160-B
Old 11-25-2021, 08:21 PM   #27
Synchro909
Synchro909's Avatar
Originally Posted by Ruth View Post
Thanks Ruth. Is the filter I see inside there made of paper? Looks like it.
Old 11-25-2021, 11:30 PM   #28
Model A Ron
Model A Ron's Avatar
Paper air filters are great until they get a few drips of gas on them and burst into fire. Think about the road conditions when the Model A was new and the conditions today. I think my car will survive fine without a filter in my opinion. Now an oil filter is a different story unless you change every 500 to 700 miles.
Model A Ron is offline   Reply With Quote
Old 11-26-2021, 07:08 AM   #29
aermotor
I feel comfortable without an air filter on todays roads.
John
Old 11-27-2021, 04:54 AM   #30
PalAl
PalAl's Avatar
Oil sprayed Hi-Boy K&N. My thought..... cleaner air, less chance of a backfire fire.
In service for about 6 years, remove, clean and reoil element with MMO once a year.
Just tighten the hose style clamps and it has stayed in place.
Engine runs well.
PalAl is offline   Reply With Quote
Old 11-27-2021, 10:31 AM   #31
old ugly
old ugly's Avatar
Originally Posted by Synchro909 View Post
We are RHD so none of the filters you guys use will work except maybe the "Hiboy" one but that can't be used with one of those oil filters on the side cover kits. We have to get creative. I make a fibreglass adaptor to go from carburettor throat, out through the gap between the choke rod and the column itself, then upwards. A short length of old vacuum cleaner hose connects that to a paper element filter mounted on the radiator stays. It is tight, tight, tight in there so it can take a lot of fiddling to get it right. As I have said before, The Model A is very poorly designed for RHD - there are so many simple and cheap ways it could have been improved on the drawing board.
this is creative.
RHD
even some fine metal mesh, form it over the intake of the carb and then hose clamp it on. that will stop larger size junk from getting in there.
on my drag car i had to do that (different type engine).
the return lane was dirt and the slicks being sticky would throw rocks and dirt over the car towards the engine. the worry of something going into the engine. $$$$
old ugly
Old 11-27-2021, 10:47 AM   #32
Ruth
It is a wire mesh type of material.
File Type: jpg Screen Shot 2021-11-27 at 7.44.08 AM.jpg (10.1 KB, 15 views)
Ruth
Old 11-27-2021, 03:13 PM   #33
SAJ
SAJ's Avatar
Here are my K&N filters on 2 different engines. Both right hand drive. Both model B carbs.
As Arnold says a VERY tight fit. The adaptors are just rolled, folded and brazed.
Slip fit onto inlets and held by one of the two bolts that mount inlet to exhaust manifold on one engine and a bolt into the wiper vacuum port on the other, because it has an electric wiper not vacuum.
Plugs can run anywhere from lean white (too lean and burnt inlets valves!) To dark tan, depending on GAV settings.
Carbs are not air balanced. No need if filter is big enough and non-restrictive. I got the same result with a large paper filter, but prefer the washable oiled mesh type.
Our rallies always take us over the worst, dusty fire trails and logging roads. There is no way I want all that dust in motors!
I get a kick out of the know-alls at public showings. Some even explain to their friends that these were after-market Ford options. Some just tell me I have ruined the originality. Many tell me Ford designed the engines to eat the dust without any harm!!!
One guy berated me and insisted to his audience of 3 friends that I was washing the bores by being too rich. I pulled a plug to show him light tan electrodes.
SAJ is offline   Reply With Quote
Old 05-28-2023, 11:08 PM   #34
30forfun
30forfun's Avatar
What oil type are using to oil the filter
30forfun is offline   Reply With Quote
Old 05-29-2023, 08:12 AM   #35
Y-Blockhead
Y-Blockhead's Avatar
I use K&N Air Filter Oil https://www.amazon.com/99-0516-Air-F...s%2C145&sr=8-1
Old 05-29-2023, 02:05 PM   #36
stevemclark
stevemclark's Avatar
An Air Maze keeps out the mice for me.Why does the paper filter cost more than the metal screen which is reusable.At Mike's paper is $20.25 and metal is $12.50 for just the filters.Notice the complete filter is "marked down ".
Carburetor Air Maze with original Metal Screen Filter - Tillotson - Model A Ford - Buy Online!
Code: A9600T
Model Year: 1928 - 1931
UOM: Each
Quantity in Basket: none
Retail Price: $36.95
Money Saver Price: $36.95
It's not the destination ,it's the journey .
stevemclark is offline   Reply With Quote
Old 05-29-2023, 02:27 PM   #37
California Travieso
Send a message via Yahoo to California Travieso
I have an Airmaze with the wire mesh screen. Does anyone know if there is a K&N filter that will fit the the Airmaze?
There may be a previous thread on it but I’m too lazy to look it up!
David Serrano
California Travieso is offline   Reply With Quote
Old 05-29-2023, 02:59 PM   #38
Y-Blockhead
David Serrano
The one pictured in my post #35 fits the Air Maze filter but is much taller, ~5½" for more air flow. You will have to extend the center bolt. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old 05-29-2023, 03:07 PM   #39
California Travieso
Thanks Y-Blockhead,
David Serrano
