10-31-2021, 01:41 PM | #1 |
Starter Troubles...
We have just inherited a 1930 Model A. After it had been sitting for about 5 years, we got her going pretty easily. Got it loaded on the trailer and over to our house. After about a week or so, we tried to start it, the starter turned over the engine then I saw some smoke... then nothing. I removed the starter switch and the copper contact was cracked. I replaced the switch and now when I press the starter button all i hear is a faint "sizzle" sound. Is the starter fried?
I am new to Model A, so any help would be appreciated. Thanks, Rob |
10-31-2021, 01:53 PM | #2 |
Re: Starter Troubles...
Take the starter out of the engine and bench test it on a 6V battery with jumper cables. You will see more when it's out. Are you using a 6Volt battery?
10-31-2021, 04:23 PM | #3 |
Yes 6v Battery. I tested the starter switch terminal and i have a solid 6+ volts there.
10-31-2021, 09:05 PM | #4 |
sometimes if a battery cable is loose or is not making a good connection there will be a sizzling sound as power is trying to overcome the resistance , dirty connections maybe. check all the battery cables and make sure they are clean and the mounting points are clean, bare metal.
if you have a helper have them step on the starter knob while you watch, listen, smell. you may have 6 volts but once you put all the power to the starter it the battery connection may not be good enough .
old ugly my old father-in-law told me. "listen close when people tell you how to do stuff they may know something. then do it the way you want." |
11-01-2021, 07:50 AM | #5 | |
John |
11-01-2021, 08:33 AM | #6 |
The starter is a simple electric motor. The commutator need to be clean and bright copper and the brushes have to make good contact and not be worn out. There is not to much that can go wrong except these two things.
11-02-2021, 10:06 AM | #7 |
maybe bendix isnt kicking in?
