02-17-2020, 09:17 PM | #1 |
97 stromberg on a standard 28 -possible?
Hi Everyone, I've tried to see what's out there regarding this but it seems there are a few opinions. My motor is stock. Will a 97 work or should I look at an 81 Stromberg.Thanks
02-17-2020, 11:25 PM | #2 |
Re: 97 stromberg on a standard 28 -possible?
My car ran better with the 97.
02-18-2020, 03:27 AM | #3 |
Thanks 1929, I'm guessing you're running a fuel pump?
02-18-2020, 05:14 PM | #4 |
02-18-2020, 05:20 PM | #5 |
I run a 97 on my A ,no fuel pump ,it will run up hil,l on the flat, and full throttle right down to empty.
Do a search under my posts and see the float valve mod I did, Lawrie |
02-18-2020, 06:59 PM | #6 |
“If you wax your chassis you deserve to have your chassis waxed” - 1931 Model A Standard Phaeton 1929 Model A Pickup |
02-18-2020, 10:31 PM | #7 |
A single "97" will work just fine.
If you were running a dual carb intake, 2 "81's" would work best. Chris W. |
02-18-2020, 11:08 PM | #8 |
Thanks for the suggestions guys!
02-18-2020, 11:09 PM | #9 |
Thanks Lawrie!
02-19-2020, 12:22 PM | #10 |
Location of Lawrie's Mod: https://www.fordbarn.com/forum/showt...loat+valve+mod
02-20-2020, 09:34 PM | #11 |
Use one 97, or two 81 carbs on a Model A. You can use two 97 carbs, but must run them lean.
