Old 09-11-2012, 08:48 AM   #1
jdempsey
Question 31 Victoria front seat size?
Hey Guys and Gals,
I'm a newbie to A's and have just acquired a nice older restoration 31 Vicky and am going to change out the old interior..it's in good shape but the wife doesn't like the mohair.
I've discovered that the front seats are, in fact, Tudor seats and are not original. The seats are mounted in the floor on pivoting posts and not like the original Victoria seats. Since I'm planning on replacing the interior...I'm wondering if the Tudor seats are the same size as the original Victoria seats so the upholstery would fit either? If not then I'd like to find some original seats..or even just the frame, base and springs of the original seats.
Any suggestions or comments would be appreciated!
Anybody have some old Vicky seats they'd like to part with?
Thanks,
John Dempsey
jdempsey is offline   Reply With Quote
Old 09-11-2012, 09:10 AM   #2
miss victoria
Default Re: 31 Victoria front seat size?
early victoria seats are also mounted on pivots
miss victoria is offline   Reply With Quote
Old 09-11-2012, 09:42 AM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
Before changing out the good mohair, how about just using seat covers over the seats. Upholstery is fairly expensive, and the next owner might like the original mohair.
Old 09-11-2012, 10:15 AM   #4
DaveB
I have a victoria and a tudor. Believe me ..... the victoria seats are much more comfortable. I hope you can find a pair.
DaveB is offline   Reply With Quote
Old 09-11-2012, 12:01 PM   #5
Vern
Vern's Avatar
John, the seats for a Victoria are very different from those of a Tudor. Then to add to the issue, the seats for the earlier, mostly Leatherback model Victorias differ from the later production, which are predominently Steelback versions. There is overlap between the Deluxe Phaeton for the early style and then between the A400 and the later style Victoria seats. The Victoria Association has lots of good information in some of the past issues relative to the seats. My Victoria, and early Steelback, came with a Tudor seat for the driver, and a Vic seat for the passenger. I'm with Tom on putting seat covers on if the mohair is in good shape.
Vern is offline   Reply With Quote
Old 09-11-2012, 04:02 PM   #6
Bill Cilker
Bill Cilker's Avatar
The early Victoria front seats use a different type of pivot than a Tudor. They use 2 L shaped brackets with 2 screw holes and 1 (passenger) or 3 (drivers) pivot holes per seat
The Vickie's drivers seat is 1" wider than the passengers seat. The picture is of my unrestored drivers seat
Bill Cilker, Jr
Unrestored 190A Victoria
45B, 160B & 189A
Victoria Association President
Bill Cilker is offline   Reply With Quote
Old 09-11-2012, 04:31 PM   #7
jdempsey
Thanks for all the posts! All good comments and especially the pic..definitely getting me on the right track.
Contacted the Victoria Assn and am ordering some books.
Still looking for seats if anyone has any.
Thanks a million,
John Dempsey
Old 09-11-2012, 04:58 PM   #8
mot
Registered User
mot's Avatar
i believe the DELUXE tudor also uses the same seat
mot is offline   Reply With Quote
Old 09-11-2012, 07:11 PM   #9
LukeDahlinger
Here's a Victoria/Deluxe Tudor/A-400 seat with original green mohair on it. Note how the back is more curved as well as wider than a normal Tudor Sedan seat.
Wanted- Feb. 1931 Parts Price List
www.vintagefordfacts.blogspot.com
LukeDahlinger is offline   Reply With Quote
Old 09-11-2012, 09:34 PM   #10
griffincat
John,
I have an original pair of seats. We just bought the car and are not 100% sure whether we are going to use them or not. If you have no other luck in the next week or two, shoot me a PM and maybe I will have a better idea what is happening.
griffincat is offline   Reply With Quote
Old 09-12-2012, 08:46 PM   #11
jdempsey
Another great pic, Luke...very interesting. Thanks.
Griffincat I sent you a PM, sounds like just what I need if your not going to use them.
Thanks,
John
Old 11-29-2012, 05:44 PM   #12
vulture
vulture's Avatar
I have a few seats and one set for a early Vicky were the seat were adjusted with a rod that went thru a tube .The other set is a 31 deluxe tudor drivers wide seat and passenger narrow curved back seats 200 bucks a set your choice
Wanted Roadster Pick up thank you COLOR]
vulture is offline   Reply With Quote
Old 10-06-2019, 02:05 PM   #13
ford2831
What is a pair A 400 seats worth ?
ford2831 is offline   Reply With Quote
Old 10-06-2019, 03:45 PM   #14
Oldbluoval
Oldbluoval's Avatar
Same as Vicky
Oldbluoval is offline   Reply With Quote
