Old 05-26-2018, 09:06 AM   #1
divcoone
divcoone's Avatar
Default Broken bendix bolt
Knew this might be a challenge. Went fishing for the head with a flexible magnet wit no success. Was going to stick a magnet on the flywheel but discovered the flywheel locks up immediately. I can turn the flywheel backwards with no problem. As soon as I crank it normally, it locks up.
If I drop the radius ball, will it give me access to the bottom?
Thanks, Bob Giles
divcoone is offline   Reply With Quote
Old 05-26-2018, 11:57 AM   #2
1955cj5
1955cj5's Avatar
Default Re: Broken bendix bolt
Dropping the radius ball will give a little access..., but it's much further back than the flywheel, more under the clutch release shaft.
Would a dab of something really sticky...maybe wheel bearing grease?...on the flywheel maybe stick to and pick up the bolt head as you turn the flywheel?
Attached is a picture of a 4-speed clutch housing. But you can see the radius ball hole is not very large....
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 05-26-2018, 01:12 PM   #3
divcoone
divcoone's Avatar
I got it. I tried the grease. It didn’t pick it up but it must have moved it enough that the magnet found it. After talking with Snyder’s, I ordered the new style bendix, American made. I found that it’s a little bit bigger in diameter and won’t go in without removing the block water neck.
Old 05-26-2018, 01:42 PM   #4
1955cj5
1955cj5's Avatar
Well, glad you got the bolt....
Model A's are a little like life, one darn thing after another.....but worth it!!
That oversize bendix has come up before.....seems there is a trick to getting it in...I'm sure you have tilted it every which way....
Maybe the trick was removing the water inlet elbow...
Old 05-27-2018, 09:27 AM   #5
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Reminds me, unbolted the water pump from the generator on an OOOLD Rambler. Couldn't get it out, then it MYSTERIOUSLY fell out????---I almost NEVER got that Dude back in!!!
Bill Cussing
"THE ASSISTANT GURU OF STUFF"
Old 05-28-2018, 06:08 PM   #6
1955cj5
1955cj5's Avatar
The thread about the tough-to-fit new style bendix surfaced...
https://www.fordbarn.com/forum/showthread.php?t=237984
He was able to get it in by just taking the dip stick out!......
