Old 04-03-2021, 01:33 PM   #1
corvette8n
corvette8n's Avatar
Default From bad to worse
https://www.fordbarn.com/forum/showthread.php?t=296663
So after I did the compression test, I decided to back the car out into the driveway to hook up my vacuum gauge. No start, tried some starting fluid down the carb no dice, plugged the timing light into one of the wires, no spark. I measured the power at the top of the coil, 6 volts, that doesn’t seem right. So I guess the dizzy needs to come off, how do I check the resister under the dash.?
File Type: jpg E1A73250-E610-42B3-B450-9660CF02E856.jpg (67.6 KB, 82 views)
Old 04-03-2021, 02:51 PM   #2
rich b
rich b's Avatar
Default Re: From bad to worse
I don't think a reading of 6 volts across the resistor under no load is necessarily bad; maybe I'm wrong about the first part; but you do need to figure out why there is no spark when you do have juice to the coil.
Old 04-03-2021, 03:35 PM   #3
corvette8n
corvette8n's Avatar
So what’s the best way to test this style coil, Skip rebuilt mine about 3 yrs ago but I have no spark.
File Type: jpg 5FB42D67-D58F-4DF7-B8C5-44071D63397A.jpg (19.6 KB, 10 views)
Old 04-03-2021, 05:40 PM   #4
Andy
You can check low voltage resistance from the terminal on top to the spring contact on the bottom. It should be low ohms. Like 2-3. The high voltage windings are high ohms. It should be 10000 ohms or so.
Andy is offline   Reply With Quote
Old 04-03-2021, 05:45 PM   #5
alanwoodieman
pull the rotor button off the shaft and look for carbon tracks on the shaft--could be shorted out!
Old 04-03-2021, 05:54 PM   #6
aussie merc
aussie merc's Avatar
shorted rotor is more common than you think specially now nos stock is getting harder to get ive actualy seen where they have put heat shrink under the rotor to help stop this
aussie merc is offline   Reply With Quote
Old 04-03-2021, 05:54 PM   #7
Jack E/NJ
Jack E/NJ's Avatar
>>>So what’s the best way to test this style coil,>>>
Make a spark. 8^) Put a plug in an old 440 boot. Tape 440 center wire to coil's high-tension brush. Hot wire coil. Ground plug. Momentarily pigtail coil's point contact to ground. Look for a plug spark. Jack E/NJ
Old 04-03-2021, 06:01 PM   #8
aussie merc
testing resistor can be done at the coil connection test light at the wire to earth turn on should be bright but will start to loose some of it brightness around 30 seconds as the resistor takes effect should stabilize around 4.5 volts [need the test lamp as modern multimeters dont draw enough current to effect the resistor]
Old 04-04-2021, 09:47 AM   #9
deuce lover
deuce lover's Avatar
If you have a multimeter you can clip it to the terminal on top and the other to the terminal that the condenser attaches. If it buzzes the circuit is closed so you should at least have spark.That test doesn't mean that the coil is completely good.When coils get hot the circuit can break also.Now the condenser is another story.I would replace it or try another.
deuce lover is online now   Reply With Quote
Old 04-04-2021, 10:42 AM   #10
marko39
To test resistor the points must be closed. With ignition on you should have 6 volts entering resistor and 3-4 volts leaving which is what you should see at coil. If you have 6 volts at coil car should start although it would be wise not to run it very long.
marko39 is offline   Reply With Quote
Old 04-05-2021, 06:48 AM   #11
Frank Miller
Frank Miller's Avatar
Not completely familiar with this coil but there is a wire that goes to the points. If you connect a test light to that and crank the engine with the key on the light should turn on and off. If it stays on you have a bad connection at the points and they will need to be cleaned.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound
Frank Miller is offline   Reply With Quote
