Old 12-28-2019, 03:54 PM   #1
Pandersen33
Pandersen33's Avatar
Default Copper in oil?
I changed the oil on my 35 with what I believe to be the original motor. Just a tad bit of gray sludge on the cap which seems like good news but when inspecting the catch pan there are several clumps of what look like copper-ish material. Engine seems to run fine even with lower compression in a couple of cylinders. Are these deposits somewhat normal? It is my second oil change after having the car for about a year. Again i know the engine is tired but is this a real bad sign? Thanks
Pandersen33 is offline   Reply With Quote
Old 12-28-2019, 06:21 PM   #2
Kube
Kube's Avatar
Default Re: Copper in oil?
My guess and only a guess is the bearings are coming apart.
I can't think of anywhere else copper would be coming from.
Engine experts? What say you?
Old 12-28-2019, 06:27 PM   #3
Emmit51
Emmit51's Avatar
How sure are you it is copper? From the post sounds like it could just be copper colored stuff. Is it metal filings, or just sludge?
Emmit51 is offline   Reply With Quote
Old 12-28-2019, 06:56 PM   #4
34PKUP
34PKUP's Avatar
Probably the best way to find out what's in the oil is to get it analyzed rather than wild guessing.
34PKUP is offline   Reply With Quote
Old 12-28-2019, 07:00 PM   #5
Kube
Kube's Avatar
Uh duh. Why didn't I think of that? Good advice sir, good advice.
Old 12-29-2019, 08:38 AM   #6
Frank Miller
Frank Miller's Avatar
Blackstone labs in Indiana sends you a whole kit. Just drop it off at the post office.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound
Frank Miller is offline   Reply With Quote
Old 12-29-2019, 10:19 AM   #7
tubman
tubman's Avatar
I did the Blackstone Labs thing a couple of years ago. It was quick and easy, and if I remember correctly, it cost $25. I got the kit at my local NAPA.
Old 12-29-2019, 03:42 PM   #8
Ol' Ron
Ol' Ron's Avatar
AS far as I know, copper bearings were used ih heavy duty truck engines. But may have been installed during a rebuild.
Old 12-29-2019, 09:39 PM   #9
r_reed
r_reed's Avatar
copper isn't magnetic, does the copper colored sludge stick to a magnet?
1949 F-1 Flatrod II (flat paint, flat motor)
Keeping one more flathead alive
It smoked, but gave it up 7/26/2013
East Glenville NY
r_reed is offline   Reply With Quote
Old 12-29-2019, 10:33 PM   #10
VeryTangled
VeryTangled's Avatar
Now we're getting somewhere...
-Jeff H
Old 12-29-2019, 10:52 PM   #11
40 Deluxe
If it's "clumps", could it be from the mesh in the oil breather cap that disintegrated into the pan?
Old 12-31-2019, 09:44 AM   #12
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
I was a fleet mechanic for Speedway police etc in the early 80s and we used Kendal oil. Every oil change was sampled and put in a small tube to be analyzed. I had a book with a test sheet for every vehicle.
Couldnt believe the dollars we saved. All bearings have copper in them . Our reports would include copper-bearings,water/antifreeze-leaks, chrome-piston rings, cast-camshafts etc...fuel in the oil . Saved us a ton , even sent a new ford back for warranty repairs based on two samples high in cast iron , had camshaft lobes coming apart at 10,000 miles ........
https://search.yahoo.com/yhs/search?...%20compisition
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 01-01-2020, 03:55 PM   #13
Pandersen33
Im 90 percent sure this is copper. Unfortunately i did t spot it oluntil i dumped the pan into a larger jug of other used oils.
File Type: jpeg FD30435D-6432-4DC8-9BB7-FE591F5D2994.jpeg (141.3 KB, 87 views)
Old 01-01-2020, 10:36 PM   #14
JSeery
JSeery's Avatar
Should be more of it in the oil shortly! Plus I'd be fairly sure the block was not cleaned out that well with just a normal oil change.
Old 01-02-2020, 01:44 PM   #15
Ggmac
Could it be rust ? If you need to remove the oil pan , check the 4 core plugs on the pan rail .
Old 01-02-2020, 02:07 PM   #16
flatjack9
flatjack9's Avatar
If that is all copper, you've got a major problem.
